Pocket GPS World :: View topic - Garmin 76 turns off when knocked
dorsetjon
PostPosted: Sun Apr 03, 2005 11:05 pm    Post subject: Garmin 76 turns off when knocked Reply with quote
I find my Garmin 76 shuts down when it is knocked or jolted. It doesn't take too much to cause it to shut down so this is a big problem. I have had the unit for just over a year and the problem has got worse.
A Google search brings up lots of web sites where people report problems with Garmin units shutting down with high levels of vibration, eg when used on the handlebars of a trail bike. This appears to be caused by the batteries moving. However, it takes a gentle knock to shutdown my unit, the sort that occurs through normal use.
In case this is a battery issue, I added "padding" to the battery compartment but it didn't help; I then removed the battery cover and held the batteries tightly in place by hand and knocked the unit - it shutdown; I then moved the batteries side to side, etc, to see if moving them in their slots would cause the GPS to shutdown, but it didn't; finally, I have noticed the unit only shuts down from knocks when in normal mode, but is fine when in simulator mode.
Can anyone help?
Thanks,
Jonathan
PostPosted: Sun Apr 03, 2005 11:21 pm    Post subject: Reply with quote
I'd suggest this would be best resolved by a call to Garmin.
