jwf3373 Occasional Visitor
Posted: Wed Mar 23, 2005 9:55 am Post subject: Problems connecting Polstar bluetooth receiver to Ipaq 4700 |
Hi all,
I've been desperately trying to connect my polstar gps PBT111 to my ipaq 4700.
I did a discovery from the ipaq and it identified the polstar device and created it as a bluetooth SPP slave.
I can connect to the slave and the signal is good - the blue light on the device stays solid and i can get a signal on the polstar device showing it can see the satellites.
When i use the pda tester software from polstar and do a scan it cannot find the device on any port - on the normal bluetooth port COM5 (incoming) and COM8 (outgoing). Com5 says 'None', Com8 says 'Fail'.
When i use the TT3 GPS screen there are no dots moving between the deive even though I have set it up on TT Wireless - Port COM5 Bluetooth.
Any help greatly appreciated!
Jame.s |
lbendlin Pocket GPS Staff
Posted: Thu Mar 24, 2005 5:41 am Post subject: |
There's your problem. TomTom needs to be set to COM8, and then the TomTom GPS driver is blocking the other programs from accessing the BT GPS. Have a read of our article describing the BlueTooth setup for TomTom _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Mar 24, 2005 10:13 am Post subject: |
Thanks for this - whereabouts is the article you are referring to please - i have done a search on bluetooth tomtom setup but cannot find it - I apologise as i am new to the forum....
thanks
JAmes |
Posted: Thu Mar 24, 2005 11:33 am Post subject: |
also, i've just dropped down the list box on the TT3 GPS screen for the port selection and COM8 is not shown at all in that list - it just shows IR port (twice), COM4, Serial cable on com1; serial on usb and bluetooth serial port on COM5!
Any other ideas??
Have deffo checked the bluetooth config and COM8 is outgoing and COM5 is incoming..
Thanks again all
James |
Posted: Thu Mar 24, 2005 2:51 pm Post subject: |
Read the Announcements at the top of the TomTom Navigator forum. _________________ Lutz
mrdavey Occasional Visitor
Posted: Fri Apr 22, 2005 8:58 pm Post subject: |
I have the same problem! I am able to connect to the polstar gps but I receive no data.
The postar test program says it's waiting for nmea when i select com5.
This worked perfectly with my ipaq 5550 and still works perfectly with my laptop.
Is there an issue with the wm2003se bluetooth software?
Thanks,
Dave |
enseenet Occasional Visitor
Joined: Mar 30, 2005 Posts: 2 Location: Rickmansworth
