Pocket GPS World :: View topic - SIRF+NMEA
SIRF+NMEA
IanRimmer
PostPosted: Fri Feb 18, 2005 6:56 pm    Post subject: SIRF+NMEA Reply with quote
Hi all im using a fortuna clip on with Ipaq 2210 and MM i can only get the clip on to show my position using NMEA
I thought the clip on used Sirf any ideas???
Cheers Ian
PostPosted: Fri Feb 18, 2005 10:49 pm    Post subject: Reply with quote
It uses a SiRF chipset. This chipset is capable of issuing data either in NMEA mode (text) or in SiRF mode (binary).
For street navigation this is completely irrelevant. If your system works fine as is then DON'T TOUCH IT . Keep using NMEA, and save yourself some of the hassles of switching back and forth between protocols.
IanRimmer
PostPosted: Sat Feb 19, 2005 12:32 am    Post subject: Reply with quote
Thanx for the replie and i do use NMEA for tomtom but tried sirf with memory map and nothing?!?!
just cant understand y? and what would the difference be with the 2??
PostPosted: Sat Feb 19, 2005 1:31 am    Post subject: Reply with quote
I think I explained the difference (text vs binary)., Most programs (like MemoryMap) don't even understand SiRF, and require that you have a NMEA receiver.
As I said, for what you are doing the protocol does not matter, so stay on NMEA for your own benefit.
IanRimmer
PostPosted: Sat Feb 19, 2005 10:20 am    Post subject: Reply with quote
Sorry u did explain just a bit slow text as in letters binary as in numbers Embarassed
oh well i might not be the brightest Idea
I just thought one might have been more accurate Laughing
22.051 (01 May 24)
