Pocket GPS World :: View topic - IPAQ rz3715 and Fortuna bluetooth clip on
britbulldog1
PostPosted: Sat Jan 29, 2005 12:19 pm    Post subject: IPAQ rz3715 and Fortuna bluetooth clip on Reply with quote
Hi guys I bought these this week and think that I have set them up correctly, I have both lights on the GPS but don't seem to be able to get anything out of the PDA to give me any info on location, can anyone please give me any pointers,I have read through most of the posts and don't seem to be able to solve the problem.
I am running Tom tom 3.
RZ3715
Fortuna bluetooth GPS,
What settings should I have on my IPAQ and how should I be able to get a fix on a satellite
any assistance would be greatly appreciated as it is very frustrating
thebatterystall
PostPosted: Sat Jan 29, 2005 2:04 pm    Post subject: Reply with quote
You say 2 (Two) lights on the GPS Confused
On the Fortuna there are 3 (Three).
(1) Blue - flashing means Bluetooth connection from the PDA
(2) Green - A fixed link to satelites
(3) Green - Your Fortuna is powered up Ok
Have you a bluetooth connection ?
Tom Tom Go 300
Brodit mounts
britbulldog1
PostPosted: Sat Jan 29, 2005 3:21 pm    Post subject: Reply with quote
some of the time i get a green light on the GPS signal and sometime I get the bluetooth blue LED lit, but then goes out after a while,
I do get the power light on green all the time.
But still no joy connecting
thebatterystall
PostPosted: Sat Jan 29, 2005 7:24 pm    Post subject: Reply with quote
If your getting Bluetooth connection i.e. Blue LED flashing constant, and both Green LED's are on permanently, then it has to be your setting in TTN via GPS Status.
Have you downloaded ttnupd307 ? and installed it on your PDA ?
I got the same problem until I had installed ttnupd307. Then I found Bluetooth Serial Port COM8 which cured it.
My settings are NMEA 0183v2 38400 with Bluetooth Serial Port COM8.
Hope this helps
Tom Tom Go 300
Brodit mounts
DavidW
PostPosted: Sat Jan 29, 2005 10:07 pm    Post subject: Reply with quote
thebatterystall's answer is correct - you need GPS 3.07 for the latest iPAQs. You should really install TomTom Navigator 3.07 on a WM2003SE machine, too - both are available from the downloads section of support.tomtom.com
britbulldog1
PostPosted: Sat Feb 05, 2005 4:44 pm    Post subject: Reply with quote
thanks for the help guys, I updated with 3.07 and it came up with comport 6 and in came the satellite no problem, the reason why I lost it was I had to do a hard reset and forgot that I had updated TomTom.
Laughing
22.053 (15 May 24)
