Pocket GPS World :: View topic - xda2 and tomtom3 nav help needed
nuttynicols
PostPosted: Wed Jan 19, 2005 6:08 pm    Post subject: xda2 and tomtom3 nav help needed Reply with quote
Can you help i have a xda2 which i loaded tomtom 3 navigator .
how ever i have tried connecting this and the tomtom say GPS DISABLED.
When i touch the screen a icon say "unable to lauch the gps control panel"
Please help if you can i we be grateful.
andy1turner
PostPosted: Thu Jan 20, 2005 11:32 am    Post subject: Reply with quote
Hi there
I'll try to help but I'm a relative newbie as well.
First check Tom Tom blue light is flashing and als that the green light flashes occassionally. I uderstand that the geeen light flashes as the GPS receiver gets a fix from a satellite.
Now make sure that Bluetooth is up and running on the XDA.
Now two ways to do the same thing.
In Tom Tom get to a map display. From the menu at the bottom select File, GPS Status.
You shoud get a GPS screen showing postiton etc. If this is all greyed select second tab and ensure that box at top left hand corner has a tick, if not touch it with stylus until a tick appears.
Other way is to go to Start menu, settings, GPS Status and do as above. You get to the same place but in two diferent ways.
I assume you are using the Tom Tom Bluetooth GPS receiver?
I have found this a little flaky at timesand sometimes a soft boot fixes these type of problems.
HTH
Regards
Andrew Turner
I don't think that your bad planning is any reason for me to have an emergency!
PostPosted: Thu Jan 20, 2005 11:47 am    Post subject: Reply with quote
It would help to know which GPS Receiver you have here. Not being able to launch the GPS Control panel suggests a re-install of the GPS Driver may be in order, insert the install CD and follow the prompts to re-install.
nuttynicols
PostPosted: Fri Jan 21, 2005 2:13 pm    Post subject: Reply with quote
Sorry guys i have a tomtom none bluetooth gps satellite receiver
The gps has no signal and the program is in gray everything showing 0
the gps tab is ticked and on tomtom navigator gps
serial cable is on com1
the connecter that i use in the car says
ic-ipq38-grs x0100310 for ipaq
could i have the wrong cable
PostPosted: Fri Jan 21, 2005 2:27 pm    Post subject: Reply with quote
Have you disabled 'receive all incoming beams' in Start | Settings - Connections/Beam ? If not you'll need to do so to allow access to COM1 on the XDA.
andy1turner
PostPosted: Fri Jan 21, 2005 2:47 pm    Post subject: Reply with quote
Hi there
I'll bow out now and leave you in Darren's tender hands. I'm sure he will be able to get you up and running.
Regards
Andrew
22.051 (01 May 24)
