Pocket GPS World :: View topic - GPRS Set up on o2 - Success at last!!!
mixer25
PostPosted: Sat Nov 27, 2004 2:55 pm    Post subject: GPRS Set up on o2 - Success at last!!! Reply with quote
I have tried and tried to set up my ipaq 2210 with GPRS on 6310i, I managed dialup no problem, but GPRS is so hard and so many different settings on the net...
eventually I phoned o2 and spoke to a very helpful person who gave me the details... at last it works...
Mobile Web Bluetooth Settings
Pairing the devices
Tap on the Bluetooth manager icon and make sure the Bluetooth radio is turned on
Now Tap on the Bluetooth manager icon again then tap on the Bluetooth manager option
make sure that Bluetooth is turned on on the handset
On the iPAQ tap on Tools->paired devices
Click on Add then click on the search Icon which looks like a magnifying glass on paper located to the right of the Device field
Tap on Your handset name and enter any passkey then press OK
Press Accept or Yes on the handset and then enter the passkey which you entered into the iPAQ on the handset
You should now see your handset ID displaye on the iPAQ screen, press OK
Tap on New->Connect select Connect to the internet option and press Next
Select Connect via a dial-up device such as a cellular phone then press Next
Tap on where it says "Tap here to choose a device" and select your handset name
Leave create a shortcut for this connection Ticked and then click Finished
Tap on New Connection... and enter the following: -
Connection Name: O2 Mobile Web Bluetooth
Country Code: Leave blank
Area Code: Leave blank
Phone Number: *99# for Nokia handsets OR *99***CID NUMBER# for Sony Ericsson handsets then press OK
Username: web
Password: password tap on save password and press OK
It will now try and connect tap on Settings on the connection window
Select manage existing connections
Select O2 Mobile Web Bluetooth and press Edit
Tap on Next 2 times then tap on Advanced
Remove the Tick from Wait for dial tone before dialing
Enter +cgdcont=1,"ip","mobile.o2.co.uk" in the Extra dial-string commands
NOTE: this doesn't appear to work with some newer handsets (eg Sony Ericsson S700i or T630) and the following should be tried;
- For Nokia handsets enter only &f in the Extra dial-string field
- For Sony Ericcson handsets enter only z in the Extra dial-string field
- The APN setting of mobile.o2.co.uk must be in the handset
Tap on TCP/IP and remove the Ticks from use software compression & Use IP header compression
Tap on Servers and then tap on Use specific server address and enter the following: -
DNS: 193.113.200.200
Alt DNS: 193.113.200.201 then press OK then Finish
Press OK until you get back to the today screen
You should now be ready to connect
Mobile Web IrDA Settings
Tap START
Tap Settings
Tap Connections
Tap the connections Icon
Tap New
Enter O2 Mobile Web as the connection name
Select Generic irda as the modem driver
Tap Next
Enter *99# for Nokia handsets OR *99***CID NUMBER# for Sony Ericsson handsets
Tap Next
Username: web
Password: password
Tap on Advanced
Leave baud rate at 19200
Un-tick Wait for dial tone before dialing
Enter +cgdcont=1,"ip","mobile.o2.co.uk" as the extra dial string commands
Tap on TCP/IP
Leave Use server-assigned IP address Ticked
Un-tick both use software compression & use IP header compression
Tap on Servers
Tick Use specific server address and enter the following: -
Press OK
Press Finish
Keep pressing OK until you get back to the Today screen
NB: Before attempting to connect make sure that Beam is turned on, on the iPAQ and also IRDA is switched on, on the handset
To enter the POP3 settings
Tap START
Tap Inbox
Tap on Accounts->New Account
Input your email address ie.o2datasupport@o2.co.uk and tap Next
It will now automatically configure your settings, wait until it says status completed
Tap on Next and enter the following: -
Your name: Joe Bloggs
User name: o2datasupport@o2.co.uk (This must be the customers POP3 username)
Password: password (This must be the customers POP3 password)
Tap Next
Account type: POP3
Name: O2 Email (this can be anything)
Tap next
Incoming mail server: mail.o2.co.k>
Outgoing mail server: smtp.o2.co.uk (This must be set to this for any pop3 account)
Domain: Leave blank
Tap on Options
Tap on Next 2 times
Choose either Get message headers only OR Get full copy of messages
Tap on Finish
Now click on the send and receive icon
