Pocket GPS World :: View topic - medion navigation system
ting21
PostPosted: Mon Dec 20, 2004 9:51 pm    Post subject: medion navigation system Reply with quote
can anyone tell me is there a quick way of adding my maps info back on to my medion as my daughter has run the battery down that low that the navigation stuff seams to have been deleated off my system as when i tryed to use it a message comes on screen saying FIRST TRANSFER A MAP TO YOUR PDA WITH MAPEXPORT TOOL im new to useing this and havent had chance to read anyting about the item as yet
PostPosted: Tue Dec 21, 2004 12:33 am    Post subject: Reply with quote
You should have installed the map to storage card instead of main memory. Do as you are told = use the map export tool on your PC to copy your prepared map over to the PocketPC (assuming that one sits in its cradle and is connected via ActiveSync) or directly to the storage card via a card reader.
crankyman
PostPosted: Wed Dec 22, 2004 12:24 am    Post subject: Reply with quote
The map info should already be on your memory card, what you need to do is re-install the programme so that it knows the maps are there.
If you run file explorer (in the start menu usually) and navigate your way to the storage card you should find a file called medion navigator, if you tap on that it should re-install everything again. :D
good luck.
Jon.
