Pocket GPS World :: View topic - Supplier for power connectors.
th
PostPosted: Tue Jul 27, 2004 8:00 am    Post subject: Supplier for power connectors. Reply with quote
Hi.
I want to hardwire a tomtom carkit (for the PDA not the BT GPS unit). Happy with what needs to be done re connecting to the vehicles wiring loom but I'm having trouble finding a supplier for the connection into the mount. I really want a connector where the cable comes out of the jack at 90 degrees to the plug - hope that makes sense. Maplin have them as a straight connector but not the 90 degree type.
Want to keep as neat as possible and don't really want to cut the one off of the cigar lighter cable that came with the kit.
Anyone able to help?
Thanks.
th
PostPosted: Tue Jul 27, 2004 2:01 pm    Post subject: Reply with quote
remember you still need the 12V > 5V converter. so why don't you install a hidden cigarette lighter socket in the dash and then just use your existing power supply?
nej
PostPosted: Tue Jul 27, 2004 4:07 pm    Post subject: Reply with quote
The kits run at 12/24v - the step down is done in the cradle, as far as I can tell, not in the plug itself, so shouldn't need to worry about the 5v thing. You might be able to just snip the cigarette adapter bit off of the existing cable and wire it in.
I think TomTom used to do a hardwire cable. Drop them a line and ask them.
Failing all that - try RS.
th
PostPosted: Tue Jul 27, 2004 7:04 pm    Post subject: Reply with quote
Thanks nej will try RS & Tomtom.
You're right the step down is done in the cradle as power coming out of cigar lighter cable is 12v.
Ideally want to keep the supplied cable in one piece so that I can use in a different vehicle.
th
th
PostPosted: Tue Jul 27, 2004 10:55 pm    Post subject: Reply with quote
Tomtom say they have stopped making the hardwire cable and don't have any in stock.
Same as the BT cradle - if the Navigator 3 and BT receiver wasn't so new to the market I would think they bringing to end of life.
Oh well the search goes on.
th
th
PostPosted: Sat Aug 07, 2004 10:15 am    Post subject: Reply with quote
For anyone who's interested I finally found the 90 degree connector that I was looking for at http://www.rapidelectronics.co.uk/
Mr. Green
th
dlegros
PostPosted: Sun Aug 08, 2004 4:45 pm    Post subject: Reply with quote
Does TT use the 2.1 or 2.5 mm connector?
Ta
dom
th
PostPosted: Tue Aug 31, 2004 10:12 pm    Post subject: Reply with quote
2.5 mm
Steve999
PostPosted: Wed Sep 01, 2004 9:30 am    Post subject: Reply with quote
I'd double check the size if I were you. Most connectors to Tomtom units (and a lot of other units also), are a 1.7mm size.
I believe it's measured on the size of the pin that goes into the connector and not the external diameter.
1.7mm connectors are rather more difficult to get hold of.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
Mac1
PostPosted: Wed Sep 01, 2004 3:18 pm    Post subject: Reply with quote
sorry to hijack the thread, i could also do with some hard wiring advise.
I've ordered a brodit hard wired mount and will run this off power at the front of the car, straight forwrd. However i also need to power a bluetooth reciever and a re radiating ariel in the boot area. I will have a distibution block for a stereo amplifier in the boot powered directly off the car battery can i power the two from this safely ?
