Pocket GPS World :: View topic - Moving Destinator from PDA to PDA
GPSinC3
PostPosted: Mon Jul 19, 2004 12:02 am    Post subject: Moving Destinator from PDA to PDA Reply with quote
I am about to chantge PDAs, from a Loox to an IPAQ 2210, I think I'm correct that I can install on IPAQ from PC and then connect to Destinator to change registration, but would appreciate any advice or experiences. What happens to the D3 on Loox will it still work ?
PostPosted: Mon Jul 19, 2004 2:16 am    Post subject: Reply with quote
You have to deregister from the Loox, and then re-register with the iPAQ. This approach means you cannot use Destinator on the Loox after that.
Make sure you do a full backup of the Loox before you do this, in case you want to go back to your previous setup Mr. Green
GPSinC3
PostPosted: Wed Aug 25, 2004 10:27 pm    Post subject: Reply with quote
As a matter of interest you can now swap PDAs and get a new code from the Desdtinator site by entering CD codes and PDA generatede code when you install. This actually leaves D3 on the old PDA but of course you could not restore this if anything happened and is naturally not legal
bandd
PostPosted: Sun Oct 10, 2004 8:22 pm    Post subject: Reply with quote
My wife and I both have Dell Axim X5s. Can I not have the program on both pda at the same time. If not, then it's hard to justify paying the cost of two programs. It's not that much better...
PostPosted: Sun Oct 10, 2004 8:36 pm    Post subject: Reply with quote
No, legally you need to have two licenses to run the program on two PDAs.
nGage
PostPosted: Sun May 22, 2005 1:43 pm    Post subject: Reply with quote
What if you installed on a storage card that you moved from one PDA to another. You would only have a single use which would seem to me to be perfectly above board.
PostPosted: Sun May 22, 2005 1:54 pm    Post subject: Reply with quote
technically yes. However the license is linked to the device ID, so you will have to deregister one device ID and register the other (which is possible). Simply moving the storage card around will not work.
22.052 (08 May 24)
