Pocket GPS World :: View topic - new fortuna
new fortuna
andy-c1
PostPosted: Thu Feb 24, 2005 11:03 pm    Post subject: new fortuna Reply with quote
i wonder if anyone can help me ,i have just recieved a new clip on bluetooth,it has all bonded ok and does work fine but everytime i start tomtom it brings up the bt manager and i have to press the right icon ( as i have 2 now also have mobile connection)then tt starts ,also while i think of it the fortuna bond has a big ? (question mark) though it
are these both correct way in which things should happen
thanks
better change my sig as well :D
TomTom 5001
andy-c1
PostPosted: Thu Mar 03, 2005 6:40 pm    Post subject: Reply with quote
90 views ?????
can't anyone tell me how it is suppose to work ,as i am almost about to send it back
TomTom 5001
harry66
PostPosted: Tue Mar 08, 2005 2:30 pm    Post subject: Reply with quote
Mine does that too - I assumed that was normal behaviour because I saw a discussion somewhere on how to hack the Registry to stop the BT Manager from popping up each time.
I also see a big ? on the Fortune icon.
I have been using my Fortuna in the above way for the past few months and not thougth anything of it.
And no, I cant remember where I saw the registry hack - sorry.
asqteks100
PostPosted: Wed Mar 09, 2005 1:36 pm    Post subject: Try This Reply with quote
While stopping/starting for GPS use, follow sequence.
- Close tom-tom navigator and make sure gps viewer is also closed.
- Turn off clip on.
while starting use again,
- Switch on clip on first
- Start tomtom.
This will remind tomtom last use of clip on to be good. Else, for tomtom it lost connection and so, BT comm woth clip on is disabled.
Does it make sense?
AS
andy-c1
PostPosted: Thu Mar 10, 2005 6:30 pm    Post subject: Reply with quote
ok thanks will do that in future
TomTom 5001
nigelw
PostPosted: Fri Mar 11, 2005 6:11 pm    Post subject: Reply with quote
In Windows Mobile 2003 you can change the default BT settings. Don't know what version of Windows you have (or even if you have Windows).
Anyway, on my PDA I start the BT settings dialog. Select the "Services" tab and select the "Serial Port" service. In "Advanced..." there's a checkbox which allows you to toggle whether an outgoing connection uses the default serial port, or prompts to select a device.
I leave mine set to prompt, as I find this is the only way to re-establish the connection after a powering the PDA off then on. If I have it set to prompt then when I turn the PDA back on I get a new prompt and TT will reconnect to the GPS. If I leave it set to use the default then no new connection is established and I have to go to the gps status screen, GPS tab and select the checkbox to re-start the connection. And this quite often hangs the BT interface requiring a reset, which in turn requires re-entering the route...
DavidW
PostPosted: Sat Mar 12, 2005 1:55 pm    Post subject: Reply with quote
The behaviour you're describing, nigelw, that allows you to set a default serial port device is that of the new Broadcom (nee Widcomm) 1.5.0 Bluetooth stack, as found in the WM2003SE iPAQs, and the 6300 series iPAQ phones.
Such a feature is not present in the Widcomm 1.4.x Bluetooth stack used in the older WM2003 iPAQs.
I am surprised you're getting the hang ups. I find that all I have to do is turn on Bluetooth (I usually leave it off to save battery power), switch on my Clip On and start TomTom Navigator on my iPAQ hx4700. It connects and runs just fine.
andy-c1
PostPosted: Mon Mar 14, 2005 6:57 pm    Post subject: Reply with quote
given up with bt for the moment as it always takes ages to get going and kept having to do resets ,do things get better with a new ppc ie fewer taps
TomTom 5001
22.052 (08 May 24)
