Pocket GPS World :: View topic - POIs - General Query
Dabri
PostPosted: Tue Feb 06, 2024 2:11 pm    Post subject: POIs - General Query Reply with quote
When a POI is requested for removal, and subsequently removed, does the POI database record this as a change and therefore modify the appended date?
Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v6.80; Samsung A52.
PostPosted: Tue Feb 06, 2024 5:03 pm    Post subject: Re: POIs - General Query Reply with quote
Hi, I've just checked the back-end database to double check this.
At the moment, no, it doesn't. The date on the POI download page is the date of the last ADDITION as opposed to additions or removals.
Dabri
PostPosted: Tue Feb 06, 2024 5:20 pm    Post subject: Reply with quote
Thank you for the clarification, MaFt. Since you say 'at the moment' is there a distinct possibility of a near-term modification to fix this? Any number of businesses seem to be disappearing, which may be reflected in 'your' databases, but, since I (and others, I presume) use the date as my guide, not in my copy. I looked into this since, when recently in Cornwall and in need of fuel, I visited several deceased fuel stations. This is the cause of my recent hectic activity to update the 'Fuel' database, particularly for those areas that are less-well served.
Dabri.
PostPosted: Tue Feb 06, 2024 7:25 pm    Post subject: Reply with quote
I will try look into the code that generates to download section and see if it can be modified to use the most recent from 'date activated' and 'date removed'.
It's pretty complex code so will need to be delicate not to kill it Laughing Out Loud
Dabri
PostPosted: Tue Feb 06, 2024 7:30 pm    Post subject: Reply with quote
Thank you and Good Luck. I shall look forward to seeing a successful conclusion in the fullness of time.
Dabri.
