Pocket GPS World :: View topic - copilot 5 round trip
slatey
PostPosted: Sat Sep 25, 2004 11:13 pm    Post subject: copilot 5 round trip Reply with quote
im going to spain and just wondered if i can choose a round trip or just select my home address in the uk to return?
PostPosted: Sun Sep 26, 2004 7:55 am    Post subject: Reply with quote
I believe you should just be able to select your home address. That's if you have the full European version of CoPilot though and not just the standard UK version!
If you have created a corridor map, then it should utilise this rather than downloading the full maps which will save space.
slatey
PostPosted: Sun Sep 26, 2004 9:09 am    Post subject: Reply with quote
i have created a trip to spain on my laptop but when i download it to my pda it just locks up i dont have the full european maps is that the cause?
slatey
PostPosted: Sun Sep 26, 2004 9:18 am    Post subject: Reply with quote
it just gets to the part where the determing current position shows and the 5 bars show and the pie chart type symbol just keeps going round...
PostPosted: Sun Sep 26, 2004 4:41 pm    Post subject: Reply with quote
Although I haven't tried it, a you only have the UK map this ould pose a problem, whether it would lock up or just sit there with the spinning pizza wheel, it will be a problem because it will need to interrogate the spain map and if it doesn't exist then that will certainy cause a problem.
Do you have Major Roads installed to the PDA ? Have you tried plotting a route to a major road ?
slatey
PostPosted: Sun Sep 26, 2004 9:09 pm    Post subject: Reply with quote
i can still get around manchester no problem but my favourites have gone. the planned trip i can begin to load then its as above...
PostPosted: Mon Sep 27, 2004 7:43 am    Post subject: Reply with quote
Ok, this is where you have to be a bit careful. If you are transferring planned trips from PC to PPC then you have to re-cut the map data and send this. This also obliterates any favourites you do have on the PPC so it's usually best to either program the same favourites into the PC version or copy them from PPC to PC before you do a map export.
slatey
PostPosted: Mon Sep 27, 2004 9:38 pm    Post subject: Reply with quote
i have bought the europe maps which will arrive tues before 12.00 i hope can i key in the upgrade code into the pda? to activate the saved trip or do i have to redownload having keyed in the code in my laptop?
slatey
PostPosted: Tue Sep 28, 2004 10:00 pm    Post subject: Reply with quote
i put in the upgrade code and everything runs fine now
slatey
PostPosted: Fri Oct 08, 2004 8:03 pm    Post subject: Reply with quote
just thought thought id let you know the trip of 1600 miles each way went fine except when approaching dover where it went screwy and came up with an error code which i dont rember.also it would not work until a couple of miles outside calais.then it kept directing us off the slip road and back on otherwise well worth the money.im going there (almeria) in 3 weeks to see a friend where im going to hire a car to look around the place where some of those spaghetti westerns were filmed good bad and ugly etc its in the desert so id better not get lost Laughing Out Loud...
22.051 (01 May 24)
