Pocket GPS World :: View topic - Help Gps Disabled !!!!!!1
wheream1
PostPosted: Sun Aug 15, 2004 1:32 pm    Post subject: Help Gps Disabled !!!!!!1 Reply with quote
I have uninstalled tomtom 3 gps and now i can't get my ipaq to recognise the fortuna clip on-
I have deleted the old pairing and renewed the pairing but when i switch on tomtom 3 nav it says gps disabled, What am i missing?
any help would be greatly appreciated
TOMTOM ONE V2 ***DID HAVE: Hp Ipaq 2210, Fortuna B/T clip on, Tomtom Navigator V3.03, Tomtom GPS v3.07, 512mb Kingston sd card.
Privateer
PostPosted: Sun Aug 15, 2004 5:42 pm    Post subject: Reply with quote
What GPS setting have you got set in the GPS Driver?
I’d do a soft reset of your 2210.
Delete the pairing for the Clip-On
Do another soft reset of the 2210.
Ensure Bluetooth is on and use BT manager to create another pairing with the Clip-On (use passkey of 0000).
I haven’t got my set-up with me but you may have to tap the GPS icon in the BT Manger and make sure that it becomes SPP Slave (or something similar).
Is the Clip-On set to NMEA?
Ensure that your GPS Driver is set to the same as the Clip-On.
Robert.
Garmin Camper 770 LMT-D
wheream1
PostPosted: Sun Aug 15, 2004 6:07 pm    Post subject: Reply with quote
My tried everything to to get it to recognise, my settings are on nmea but would not connect so i have re installed tomtom gps v3.03,
the reason i uninstalled tomtom gps was becuz the tomtom navigator would just freeze up literaly evry 500yds and i would have to exit navigator and restart again, i am totally at a loss as to what to do with it now.
If you get a chance would you tell me what the best settings are to get the tomtom v3.03 to work with fortuna bt clip on, it seems if i uninstall tomtom gps then navigator will not let me set up a connection with the fortuna although i have already set up a pairing using bt manager !
Surely the navigator should not b freezing every 500 yds i can understand it if it was evry 500 miles but it's getting beyond a joke, i hav not had a single journey with the navigator working throughout.
thank u for your replies :D
alix776
PostPosted: Sun Aug 15, 2004 7:08 pm    Post subject: Reply with quote
how do you mean freezing try unckecking the reavie all beams in the ir setting and also uncheck show poi in the tt poi menu it right at the top if that dosnt work then i think it could be the storage card so you might need to format it and then reinstall the maps
device Lumia 950 xl
wheream1
PostPosted: Sun Aug 15, 2004 8:14 pm    Post subject: Reply with quote
i mean the navigator shows the n.w.s.e arrows on bottom left of screen and thats all,it breaks connection with the fortuna clip on, i then hav to shut down navigator and restart, it continues like this all the time.
i will try doin what you said, thanks for the advice :D
alix776
PostPosted: Sun Aug 15, 2004 8:17 pm    Post subject: Reply with quote
it might help have you check the box on the tt gps screen (silly i know but you never know)
device Lumia 950 xl
wheream1
PostPosted: Sun Aug 15, 2004 8:32 pm    Post subject: Reply with quote
the box on the gps screen is checked,
you meen the box with the nmea and baud rate of 38400, and bluetooth serial port com8 don't you?
wheream1
PostPosted: Sun Aug 15, 2004 8:37 pm    Post subject: Reply with quote
also you know on the gps screen,, where you have kmh and mph and kts op[tions above them you have dms dmm and dd ehat are these latter 3 circles refering to, my settings are on the mph and the dmm, is this correct? Sad
alix776
PostPosted: Sun Aug 15, 2004 9:44 pm    Post subject: Reply with quote
to be honest ive never really payed with them settings try nmea0183v2 bluetooth and com 8
device Lumia 950 xl
Steve999
PostPosted: Sun Aug 15, 2004 10:46 pm    Post subject: Reply with quote
I have a BT unit (although not Fortuna) and v3.03 and find that nmea0183v2 setting causes regular freezing of the Tomtom software as you describe.
Try selecting Tomtom Wireless GPS and COM 8. I have no freezing with that, may work for you.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
wheream1
PostPosted: Mon Aug 16, 2004 8:48 pm    Post subject: Reply with quote
Hi stevie999
8O :o Smile :D wow thank you very much Steve999
I set the gps on tomtom wireless gps and com port 8, and hey presto it worked, i have only tried it for about 2 miles so far but not a single lock up :D whereas b4 it would hav locked up at least half a dozen times in 2 miles.
4 the first time i have seen how sat nav is supposed to work !
i have used it on xtrac mode, i will try the st mode 2morow !
and i may then reinstall checkpoint 3.02 and start using poi's.
i cannot thank you eneough m8. :D
regards
wheream1
