Pocket GPS World :: View topic - Routable Map from Nuvi to Mapsource
BLBJBranch
PostPosted: Sat Oct 16, 2010 9:01 pm    Post subject: Routable Map from Nuvi to Mapsource Reply with quote
Ok, I've scoured the web for an answer to this, but I've had no luck.
I'm trying to get a routable map from my nuvi to mapsource. I found a sort of hack, where you can take the gmapprom.img file, copy it to the garmin PCBSMP2 folder, and rename it pc_basemap2.img to have it show as the basemap.
However, it does not appear to routable. At least it's not for me. It just draws a straight line between waypoints.
Can someone tell me, please, if there's a way to get a routable map from the nuvi to mapsource. (I think I've seen I can't transfer the route to the nuvi, anyway, but I still want to be able to route within mapsource for other reasons). If not, where do you get a routable map to use for route planning? I just don't understand.
Thanks.
PhilHornby
PostPosted: Sun Oct 17, 2010 12:43 am    Post subject: Re: Routable Map from Nuvi to Mapsource Reply with quote
Well if you sweet-talk Garmin into sending you a DVD containing one, or you qualify/buy a map upgrade you'll get one.
Otherwise, maybe the Garmin Basecamp product will do what you want? This uses the map in-situ on the attached unit.
Description from the help (since it seems to be missing from the web:-
Code:
Garmin® BaseCamp® provides an interface for viewing Garmin map products and managing geographic data. With BaseCamp, you can:
Transfer data to and from your GPS device.
Create, view, and edit waypoints, routes, and tracks.
Organize saved waypoints, routes, tracks, and geocaches in the Library and Devices area.
Find items, addresses, and Points of Interest (POIs) included in your detailed map data.
View map data in 2D and 3D.
View topographical information included in your detailed map data.
Geotag photos with geographical location information.
Print detailed topographical maps, Public Land Survey (PLS) quads, and multi-page poster maps.
Download and view BirdsEye™ satellite imagery.
Import and view Garmin Custom Maps.
BLBJBranch
PostPosted: Sun Oct 17, 2010 5:06 pm    Post subject: Reply with quote
That seems to work. Thanks for the info.
gatorguy6996
PostPosted: Fri Oct 22, 2010 2:16 am    Post subject: Reply with quote
Yes, using Garmin's Basecamp allows for the existing map on your nuvi (or other Garmin device) to be transferred to your computer for use with planning, trip statistics, tracks etc via Basecamp. A lot of users have asked for some way to use the map that came with their nuvi to setup custom routes or trip planning on their computer. Basecamp gives you that. While really targeted towards the handheld crowd, it works quite well for highway travel too, albeit a bit slower to work with than MapSource in my experience. But at least it's free!
Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr.
stuartb
PostPosted: Mon Oct 25, 2010 10:20 pm    Post subject: Tyre? Reply with quote
I use Tyre with my 775T. Works a treat. It uses Google Maps so you need to be online, but then you can route and then download direct to the unit.
http://www.janboersma.nl/gett/
Stuart
