Pocket GPS World :: View topic - TMC Receiver for TT720
sturgi
PostPosted: Sat Sep 11, 2010 8:54 pm    Post subject: TMC Receiver for TT720 Reply with quote
I have done a search but it pulls back loads of posts. I am looking for a TMC receiver for the TT720 and after advice on what is the best one to get as I have seen different options searching the web.
Any advice appreciated.
Ian
PostPosted: Sat Sep 11, 2010 9:09 pm    Post subject: Reply with quote
You can use the Mini USB style receiver (part number ends 014) or the round plug style unit with a part number ending 013.
The 014 unit requires power from the car to work so will lose the signal when you stop for fuel etc if your ignition switch turns off the power to the cars accessory socket. The 013 unit will draw power from the host device if power from the car isn't available. Reception quality is about the same for either device and the data isn't as good as you get with a Live HD Traffic enabled PND but it will give you a clue about issues on your travels.
There is a newer RDS receiver thats recently been released that is combined in to the power lead, this device will not work with your TomTom - Mike
sturgi
PostPosted: Sat Sep 11, 2010 9:21 pm    Post subject: Reply with quote
Cheers Mike
So the 014 my charger plugs in the the TMC so what do I use to plug in the the TT as my battery is poor. Does the TMC divert power to the TT as well? Looking at the TT website it's not very clear but looks like it is the case. TT don't appear to have the 013 anymore.
Ian
PostPosted: Sat Sep 11, 2010 9:25 pm    Post subject: Reply with quote
The 014 unit is supplied with a short (circa 4") lead with a mini USB plug on the end which you insert to the normal power socket on the TomTom, power is ted from the charger in to the RDS unit then power and RDS data are fed in to the PND via the mini USB plug thats part of the receiver - Mike
Guivre46
PostPosted: Sat Sep 11, 2010 11:04 pm    Post subject: Reply with quote
Just to confirm you need navcore version 8.351 on your TT to use the usb rds-tmc receiver. If you want the older version [013], I have seen it on the Buybits site for £24.95 unboxed. If your battery is weak then the powered usb version would be better.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
22.052 (08 May 24)
