Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 31, 32, 33, 34, 35  Next
TheGrumbler
PostPosted: Thu Nov 26, 2009 2:17 pm    Post subject: Reply with quote
linknet wrote:
TheGrumbler wrote:
Hello linknet,
is it possible to increase the size of the street name signs? They are very small on my VGA display.
Best regards
TheGrumbler
I think it might be possible but it would be a sys.txt entry and not something that can be altered from within a skin.
linknet
Thanks for your answer linknet.
And I now found the solution which might be also useful for others. As you already mentioned it's a sys.txt entry:
[3d_config]
roadsign_lines_per_screen=18
Works perfect for me.
Higher values = font becomes smaller in size
Lower values = font becomes bigger in size
TheGrumbler
linknet
PostPosted: Thu Nov 26, 2009 2:28 pm    Post subject: Reply with quote
[3d_config]
TheGrumbler
Pleased that you found a solution.
Regards
linknet
kostaschrys
PostPosted: Sat Nov 28, 2009 10:15 pm    Post subject: Re: color night filter Reply with quote
linknet wrote:
kostaschrys wrote:
Hi Linknet,
I used your skin in my old device, but my new one has a resolution of 234*480 so i cannot use it. Is it possible to apply the color night filter to default skin? The screen I have does not have dimming operation.
Yes, but you'd have to include the modification yourself.
linknet
That is the good side, the bad side is I have no idea how to do it. What I have to add and where?
If it is not troublesome please give some instructions
thanks
linknet
PostPosted: Sat Nov 28, 2009 11:05 pm    Post subject: Re: color night filter Reply with quote
kostaschrys wrote:
linknet wrote:
kostaschrys wrote:
Hi Linknet,
linknet
thanks
All I can say is that you need to create a skin for your resolution and then search the Ultra Skin for ";!MOD_MNF - Map Night Filter" entries and include these in your skin.
A set of instructions would take far too long I'm afraid.
Regards
linknet
wombleuk
PostPosted: Thu Dec 10, 2009 8:37 pm    Post subject: Reply with quote
is there anywhere I can get this without becoming a premium member of Rapidshare?
Border_Collie
PostPosted: Thu Dec 10, 2009 9:26 pm    Post subject: Reply with quote
You can get Linknet's Skin from HERE
wombleuk
PostPosted: Thu Dec 10, 2009 9:35 pm    Post subject: Reply with quote
Border_Collie
PostPosted: Thu Dec 10, 2009 10:02 pm    Post subject: Reply with quote
You can get the Skin from Linknet's download site. There's one for iGO8 and another for Amigo. Rapidshare doesn't come into it.
wombleuk
PostPosted: Thu Dec 10, 2009 10:04 pm    Post subject: Reply with quote
So you've tried following the links and they don't lead you to Rapidshare ?
Where do they take you ?
Border_Collie
PostPosted: Thu Dec 10, 2009 10:13 pm    Post subject: Reply with quote
Oh, I see what you mean, it's been a while since I got the download and forgot about Rapidshare. Embarassed
However, it does say
'There are no more download slots available for free users right now. If you don't want to become a premium member, you might want to try again later'.
Maybe you could try later and be more successful or PM me your e-mail address and I'll send you a copy of 6.0.22. Copy it to iGO8/Content/Skin folder.
(I'm sure Linknet won't mind as it's freely available).
wombleuk
PostPosted: Thu Dec 10, 2009 10:24 pm    Post subject: Reply with quote
Hmmmm
I got 'You have to be a premium member to download this file'
PM'd
Border_Collie
PostPosted: Thu Dec 10, 2009 10:53 pm    Post subject: Reply with quote
If you read a bit further down you'll see it says try again later.
linknet
PostPosted: Fri Dec 11, 2009 9:32 am    Post subject: Reply with quote
Exactly, sometimes RapidShare becomes congested, so just try again later. You will always eventually get a free slot.
linknet
kostaschrys
PostPosted: Wed Jan 06, 2010 2:16 pm    Post subject: night filter Reply with quote
Hi linknet,
I followed your istructions below, but the night filter button at scheme screen has not been created.
Any help how I can create that?
Regards
Kostaschrys
Regards
linknet
linknet
PostPosted: Wed Jan 06, 2010 11:44 pm    Post subject: Re: night filter Reply with quote
kostaschrys wrote:
Hi linknet,
I followed your instructions but the night filter button at scheme screen has not been created.
You should now have 7 modified ui files:
model_variables.ui
navigatemap.ui
navigatemap_320_240.ui
setting.ui
setting_320_240.ui
start.ui
start_320_240.ui
(replace 320_240 in the above with your resolution)
The code for the filter button (or checkbox) is in navigatemap_320_240.ui.
linknet
Page 32 of 35
