SK1N Occasional Visitor
Posted: Tue May 25, 2004 1:57 pm Post subject: TomTom 3 on Medion |
HI,
Have purchased one of the Aldi specials, (Medion PPC250).
I am interested in installing TomTom 3 on it & i was wondering what settings if any need to be changed regarding the GPS side of things.
I have read somewhere about Com port designations needing to be changed but i can`t remember where i saw it & if it was relevant to the model i have.
Any help would be greatly appreciated.
Sk1n ;) |
lbendlin Pocket GPS Staff
Posted: Tue May 25, 2004 2:19 pm Post subject: |
The TomTom GPS driver (as of 2.08 ) is bending the client serial BT connection from COM8 to COM5. And it is messing up the Bluetooth stack as well.
So if you refrain from installing the newer TomTomGPS driver and use version 2.07 instead (we have it in our Downloads area) then you don't need to change any settings. _________________ Lutz
Posted: Tue May 25, 2004 3:28 pm Post subject: |
Thanks for the reply, Although this unit is hardwired to the Gps reciever will Bluetooth drivers still cause a problem as i didn`t even know that this unit had bluetooth on it.
cheers sk1n ;) |
Posted: Tue May 25, 2004 3:46 pm Post subject: |
If you are not using BlueTooth then you should not expect any problems altogether. You can even use the latest GPS drivers (but you don't need to) _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed May 26, 2004 1:09 pm Post subject: |
Thanks for the help, installed Tomtom 3 on the Medion PPC250 this morning, Put the GB maP ON THE STORAGE CARD & EVERYTHING WORKS JUST FINE found 6 Satellites dead quick with no setting changes.
Thx again
sk1n ;) |
atonks Occasional Visitor
Posted: Tue Jun 08, 2004 10:41 am Post subject: |
What are the advantages of TTN3 over the Navigon as supplied with the Medion PPC? |
