Pocket GPS World :: View topic - 7.480, is there an upgrade
Taximark
PostPosted: Sun Nov 02, 2008 12:54 pm    Post subject: 7.480, is there an upgrade Reply with quote
Hi can someone tell me if an upgraded map is available on home, is there a v8.010 out?? I'm using a 720 western Europe.
PostPosted: Sun Nov 02, 2008 1:23 pm    Post subject: Reply with quote
The 7,480 is the software version your device is using, in order to use the latest map you will need to use TomTom Home on the PC to update it firstly to 7,481 then repeat the upgrade to install 8,010 to the device. This update must be performed as a two stage operation as the 7,481 release contains certain important files.
With the Software version 8,010 installed you can now upgrade your map, the latest map for you maching is v810, there is also the map update scheme where by you pay a reduced fee for the map updates for the next twelve months, this option will be offererd to you via the Home inteface.
Depending upon which version of Home you have installed to the PC you might want to update that to the latest build available BEFORE starting any of the above. The download page for the latest version of Home is found by clicking Here Note the download button on the left of the TT Page I have linked to is for PC and the righthand one for mac users, this should be made more obvious rather than a silly little icon - Mike
Taximark
PostPosted: Sun Nov 02, 2008 2:02 pm    Post subject: Reply with quote
Thanks for that mike, by the way what was/is the difference between 7.480 and then .481 then to 8.010 out of curiosity?
PostPosted: Mon Nov 03, 2008 6:46 pm    Post subject: Reply with quote
There's a list that I try to maintain of all software releases HERE
