Pocket GPS World :: View topic - TTG on a motorcycle !!
ned1
PostPosted: Sun Sep 07, 2008 2:44 pm    Post subject: TTG on a motorcycle !! Reply with quote
I have a TTG 720 that I am going to use on my motorcycle, what I would like to know is can I connect a earpiece to it !!
ned
Oldboy
PostPosted: Sun Sep 07, 2008 8:57 pm    Post subject: Reply with quote
I've moved this to a more suitable Section.
I'm afraid I can't give an answer to your question though. Sad
PostPosted: Sun Sep 07, 2008 9:01 pm    Post subject: Reply with quote
If you want to use a wired connection then just connect the 3,5MM stereo jack plug from the earphones to the line out socket on the base of the 720. Bury the headphones in the helmet so you will need a low profile set of cans for this, and don't expect the handsfree for the phone to work.
In Change Preferences/ Speaker Preferences set the Nav voice and music to use the Line Out socket, turn the sound down low and give it a try, increase the volume until you are happy with the level.
If you are wanting to use a wireless solution then you could try a Bluetooth A2DP headphone set, but these are very problematic to get working with the x20/ x30 units (if at all) - Mike
PeteT
PostPosted: Mon Sep 08, 2008 9:35 am    Post subject: Reply with quote
My dad uses his TT720 on his bike. He does this by plugging the the TT into the bikes intercom via the line out. He puts TT under the seat and just follows the voice prompts. This works fine for him.
22.055 (29 May 24)
