Pocket GPS World :: View topic - I Know I've Read this on here
JimCrosskell
PostPosted: Thu Aug 07, 2008 8:55 pm    Post subject: I Know I've Read this on here Reply with quote
HI everyone
I have been watching this forum with interest and have just taken delivery of a shiny new A10. How do I get rid of the 5Km or so red trail on startup? I know the solution has been posted here, but I can't find it now!
PostPosted: Thu Aug 07, 2008 9:06 pm    Post subject: Reply with quote
Welcome to the forum, press the lower right button until you get to the "Trip Log" page, press the "Reset" button and select "Reset Trail" to clear the rubbish from the screen - Mike
Oldboy
PostPosted: Thu Aug 07, 2008 9:07 pm    Post subject: Reply with quote
I don't know much about Satmaps, but this might be what you're looking for.
JimCrosskell
PostPosted: Fri Aug 08, 2008 7:55 am    Post subject: Reply with quote
Thanks Mikealder.
I knew it was simple but couldn't remember what to do.
PostPosted: Fri Aug 08, 2008 7:57 am    Post subject: Reply with quote
When you do this make sure you then start the trip log to record your walk, I have forgotten this on a couple of occasions, only to find out much later on that I have no data Embarassed - Mike
JimCrosskell
PostPosted: Fri Aug 08, 2008 3:27 pm    Post subject: Reply with quote
The rechargeable battery pack shows the charging icon forever.....
When I initially received the A10 I fitted the rechargeable battery and plugged in the charger. The unit did a few power ups and offs and ons and then settled down with the charging icon on. I left it for 2~3 hours and then took the A10 home, where I put it on charge overnight, with the screen off but the unit on. Pressed the map button at 0630 this morning and the GPS map came up instantly with a good satellite lock but the charging icon was still showing. I turned off the charger, removed the plug, switched off the A10. Then plugged the cable in again and fired up the mains. Swithched on the A10 some 4 hours later and the thing was still charging!
Any ideas please?
FrequentFlyer
PostPosted: Fri Aug 08, 2008 4:11 pm    Post subject: Reply with quote
Actually, I don't think that the icon 'turns off' after charging...well mine doesn't...strange but true !
PostPosted: Fri Aug 08, 2008 5:01 pm    Post subject: Reply with quote
I think of the icon as more of an indication the device is coupled to an external power source rather than a charge status. If its been on charge overnight you can be sure it will be at 100% - Mike
PloddinPedro
PostPosted: Fri Aug 08, 2008 5:54 pm    Post subject: Reply with quote
Agreed - the little lightning symbol will stay as long as it's plugged in to a switched on charger. I've had it confirmed from Satmap that leaving it "permanently" plugged in won't harm anything, as it's an "intelligent" charger, so I just leave mine plugged in every night as a matter of routine. So long as I've got four blocks of battery condition when I set off I'm happy. Currently, I'm getting about 11 to 12 hours of life from my Li-pol cell, in PowerSave mode, with the screen always on and at 80% brightness.
21.115 (29 Nov 23)
