Pocket GPS World :: View topic - No Speech from TomTom 1v2
popasmurf
PostPosted: Sun Jul 06, 2008 11:00 pm    Post subject: No Speech from TomTom 1v2 Reply with quote
Sad
I have a Tomtom One v2 onwhich the spoken direction's have stopped working.When you first switch on on you get the the tomtom sound so I know thw speaker is working but that is the only sound I get.It was working fine but all of a sudden the speech stopped working.I have done a Reset and a restore Factory defaults without any luck.Any ideas please?.
Thanks. Crying or Very sad
PostPosted: Mon Jul 07, 2008 6:48 am    Post subject: Reply with quote
Go to Change Preferences/ Change Voice and see which voice is selected, also is it greyed out (it shouldn't be), scroll through the list to locate the one you want to use.
If it isn't the above what output volume is selected, tap the lower left corner of the screen to access the volume slider - Mike
PostPosted: Mon Jul 07, 2008 12:33 pm    Post subject: Reply with quote
Hope that fixes it, but I'm concerned when you say "When you first switch on on you get the the tomtom sound"...
You SHOULDN'T get that sound when you just "switch on", only after a re-boot.
popasmurf
PostPosted: Mon Jul 07, 2008 7:13 pm    Post subject: Reply with quote
Sorry for the delay in replying.
Yes Andy you are right I get that tomtom sound after a reboot.
mikealder I have done that and still no sound.On setting the sound level there is an option to test the level,I tap that and no sound.
I am at a complete loss as to what to do next. Crying or Very sad
PostPosted: Mon Jul 07, 2008 7:39 pm    Post subject: Reply with quote
Is there anything for Speaker Preferences if you go through the change preference menu options, I don't think there should be but I am little lost as to other suggestions.
When you checked the voice wasn't greyed out can you scroll through the various voices to see if any appear in colour and if so does pressing test make it speak - check all langauges rather than just UK - Mike
popasmurf
PostPosted: Mon Jul 07, 2008 8:10 pm    Post subject: Reply with quote
Hi Mike,
I have tried several different langauges and none work.I have also downloaded a new voice and that doesn't work either.Is it possible there is something wrong with the SD card?.If so how would check it to find out?.
PostPosted: Mon Jul 07, 2008 8:44 pm    Post subject: Reply with quote
What software version are you on? (tap satellite strength bars and read off next page)
You could try re-installing software:
1. Make full backup with Windows Explorer (see FAQs for instructions)
2. With Explorer, DELETE all the LOOSE files on on the TT (i.e NOT in any folders) (DO NOT delete any folders)
3. Again with Explorer delete the contents of the "program" folder in "My documents/ TomTom/Home/ Downloads/ Program". (Path may be different on your machine, you can check the location in Home itself with Tools menu/ Home Preferences/Folder locations)
4. Connect TT to computer and run Home.
5. Home should automatically check for updates and prompt you to install them, if not:-
6. Click "Update my TomTom - wait to see what it offers you.
7. Select the Application update and wait for it to install.
8. Click on 'Device - Disconnect Device', wait for it to re-boot and ask if you want to connect to the computer, select "No" and when you see the normal navigation screen, turn off and disconnect.
dhn
PostPosted: Mon Jul 07, 2008 9:10 pm    Post subject: Reply with quote
May I also suggest the Clear Flash tool?
PostPosted: Mon Jul 07, 2008 9:12 pm    Post subject: Reply with quote
You may! Very Happy
Good thinking. Try that first, popasmurf....
popasmurf
PostPosted: Mon Jul 07, 2008 10:04 pm    Post subject: Reply with quote
What is 'The Flash Tool' please?
popasmurf
PostPosted: Mon Jul 07, 2008 10:37 pm    Post subject: Reply with quote
5.450
I have connected tomtom to PC and openend Home,but home does not find tomtom.Windows finds tomtom with no problem?
dhn
PostPosted: Tue Jul 08, 2008 1:05 am    Post subject: Reply with quote
Download it here: http://www.tomtom.com/support/index.php?FID=6211&Lid=4
Run it with the unit connected to the computer. You need not use Home for it.
PostPosted: Tue Jul 08, 2008 1:20 am    Post subject: Reply with quote
Did it before?
Does it if you put those loose files back from the backup?
Do you have Home v2.3?
One of TomTom's best help files is on this topic...
SEE HERE and click on the "Device is not recognised by Home" section. They say is an 'image' file you may need.
popasmurf
PostPosted: Tue Jul 08, 2008 7:03 pm    Post subject: Reply with quote
Andy_P wrote:
Did it before?
NO
Not tried yet.See next message.
YES
popasmurf
PostPosted: Tue Jul 08, 2008 7:07 pm    Post subject: Reply with quote
I have just taken the SD card out of tomtom and put into Pc's card reader and TomTom Home started straight away!!.So I am going to try the advice given and come bavk and let you know how I get on.
Thanks everybody.
