Pocket GPS World :: View topic - Installing CF memory card stops voices on HP2210
shilcor
PostPosted: Fri Apr 13, 2007 7:07 am    Post subject: Installing CF memory card stops voices on HP2210 Reply with quote
Hi All,
I'm running TTN6 on my HP2210 with a Holox BT321 Bluetooth GPS and it works great. However, yesterday I had a 16Mb CF memory card in the 2210 as well as the 2Gb SD card that TTN6 runs from and suddenly noticed that the lovely Jane wasn't talking to me! When I tried to check the vloume settings it said that I was trying to use a voice that was unavailable. Removing the CF memory card returned everything to normal and voices worked again. It's not a big deal but I wondered if anyone else has seen this happen and if there's a way to have memory in the CF slot as well as the SD slot without losing the TTN voices. All other functions of TTN6 appeared to work correctly.
Oldboy
PostPosted: Fri Apr 13, 2007 7:18 am    Post subject: Reply with quote
It appears that there is sometimes conflict between the SD and CF Cards, when used together in, in TTN6.
A quick Search for CF Card came up with several possible problems/cures.
This is one - http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=51585&highlight=cf+card
shilcor
PostPosted: Fri Apr 13, 2007 12:12 pm    Post subject: Reply with quote
Thanks Richard. It's not a big deal. The only reason I put the CF card in was because the plastic blanking "card filler" had a small piece broken off and while I had it out superglueing it back on, I put a CF card in to stop anything entering the empty slot. BTW, the only place I can find a replacement plastic "CF Filler Card" is Expansys and they want over 12 quid plus postage - Extorsion !!! It's only a little plastic moulding so how can they justify that rediculous price ?
22.051 (01 May 24)
