IB Occasional Visitor
Posted: Mon Feb 23, 2004 12:24 pm Post subject: What's my best move? |
I have the navman 3400 sleeve for my Ipaq which I have used for over a year with their SmartNav software.
Recently I changed to Tom Tom Nav 2 software which I much prefer, but the TTFF is now unbearable! I suspect this is down to the navman hardware working with the Tom Tom driver.
So the question is, which is the best hardware to go for to work with Tom Tom Nav 2 software. I have an ipaq 3970 which has bluetooth, so that is an option, and I also already own a compact flash sleeve, so that is too.
Any comments appreciated.
Ian |
Darren Frequent Visitor
Posted: Mon Feb 23, 2004 1:28 pm Post subject: |
The answer depends on your usage and the amount of cash you have to spend. You could choose from a newer Jacket type receiver such as the Emtac, a CF GPS, a mouse GPS or a Bluetooth solution.
If your sole use is in-car then the simplest and most efficient set-up is often a GPS Mouse but you are then tiede to 12v power. CF is a convenient form factor but it is not ideal for in-car use and the most adpatable of the lot is Bluetooth but as you can guess this is the most expensive.
If you wish to use in-car primarily but have the option to use away from your vehicle on occasion with maximum compatability should you upgarde your PocketPC in the future go Bluetooth. _________________ Darren Griffin |
Posted: Mon Feb 23, 2004 2:06 pm Post subject: |
Thanks Darren
I was tending towards bluetooth, so that has sort of made my mind up.
Having a loook through the reviews, I think the GlobalSat BT308 Bluetooth GPS Receiver looks particularly good.
However I couldn't see it in the list of drivers for TomTom Nav2 - do you know if it works with the software ok? |
Posted: Mon Feb 23, 2004 3:43 pm Post subject: |
It does, TomTom does not have a setting for every available GPS (and many fo them are there just to make set-up a little easier) but so long as the one you choose is NMEA compatable (and the GlobalSat is) then it will work with TomTom perfectly. Just set TomTom to use the BT Com Port, NMEAv0183 as the protocol and 4800bps as the port speed.
Another thing is HP chose to re-badge the Globalsat BC-308 in the US for use with their GPS package so if they think it's worthy of their badge it must be a plus _________________ Darren Griffin |
