Ramases Occasional Visitor
Posted: Sun Dec 24, 2006 12:57 pm Post subject: SERIOUS PROBLEM WITH NEW POIs & GARMIN i3 |
I have just downloaded a set of new set of POIs and is has crashed my i3.
POI loader seemed to work fine but when trying to add a few more, the loader now can't find the unit.
Despite doing a full reset I cannot now get beyond the opening "Where To" or View Map" screen. It will not switch off unless the batteries are taken out and nothing works. Any help appreciated ..... |
bigant1986 Occasional Visitor
Posted: Sun Dec 24, 2006 3:21 pm Post subject: |
i have just had the same problem with my nuvi 300, it crashes at the'loading maps' screen without an external power source and with a power source it just freezes on that screen and crashes when power is removed, i've tried just about everything, GPS crashes on 24/12/06, great! |
Posted: Sun Dec 24, 2006 3:53 pm Post subject: It's not just me then .... |
Well, that's very interesting. I've posted a warning on the Streetpilot/Nuvi forum, and on uk.rec.gps and contacted Darren (PGPSW) via email. I wonder how many more people are having this problem? This could get to be a very expensive, one way or the other ......
I've emailed Garmin for their advice but don't expect a reply for some time given the proximity to Christmas. |
Pootle Regular Visitor
Posted: Sun Dec 24, 2006 4:10 pm Post subject: |
Hi Ramases,
can you confirm you have tried a factory reset as discussed here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=181827
Once complete take your i3 out to the car make sure it is running off external power with a good view of the sky and give it time (can be upto 15mins) to reaquire sat's.
If you have tried this does it still not work after this? _________________ -----------------------------------
Enjoy? WTF?
(S)ad
(A)nd
(P)roud
i3, V8, V2.7, WAAS EGNOS.
Audio V2, Simpsons Voice File
Posted: Sun Dec 24, 2006 5:02 pm Post subject: |
Pootle wrote: | Hi Ramases,
If you have tried this does it still not work after this? |
Hi Pootle
I can confirm I followed the correct reset procedure and accepted the delete option.
Have had the i3 running in my car on the drive for 20 minutes. It acquired reasonable satellite lock (three green bars - normal for this location) but fault remains as before.
Anything else you think I should try?
TIA.
Colin. |
Posted: Sun Dec 24, 2006 5:44 pm Post subject: A bit more information for the technically able ....... |
OK, following a bit of advice given elsewhere I've reset the device again and tried a combination of buttons while connected to the PC. The upshot is that POI Loader has now found the i3 but, of course, POIL reports a "communication error" then can't send any sort of POIs to the i3.
Help !!!!!!!! |
Posted: Sun Dec 24, 2006 6:13 pm Post subject: |
Have managed to get my i3 working again using a fix suggested in the POI Launch thread ...
(http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=50203&postdays=0&postorder=asc&start=45
it was all a bit hit and miss though and took me ages. PLEASE DON'T DOWNLOAD THE NEW POIS IF YOU HAVE A GARMIN GPS until we know they're safe...
Merry Xmas. |
knuttt Occasional Visitor
Posted: Sun Dec 24, 2006 8:04 pm Post subject: |
Exactly the same problem here, will try the fix above but have brought a new card of ebay with an adaptor so I can read the corrupted card on the pc and delete the POI file.
In the meantime, what a terrible time of year to be without my little i3 :-(
If I get a speeding ticket I'm going to be really miffed.
Andy |
FirebladeDreamer Occasional Visitor
Joined: Mar 07, 2006 Posts: 31 Location: Chelmsford UK
Posted: Sun Dec 24, 2006 9:01 pm Post subject: |
Are we talking speed camera database POIs or something different here? |
Posted: Sun Dec 24, 2006 9:50 pm Post subject: |
We're talking about the new general POI's that PGPSworld are now publishing.
I'm very happy bunny though because I've just managed to repair my i3.
I slipped the memory card out of the unit and then connected it to the computer, when POI Loader found the unit I asked it to remove the old POI file and then put the memory card in (sort of at the same time).
I did this a couple of times before I noticed the GPS was working normally (with the memory card inserted).
I've gone back to using MaFt's database and all is well again.
Good Luck people
Merry Christmas
Andy |
Posted: Mon Dec 25, 2006 11:12 pm Post subject: |
I personally use MaFt's poi's and the speed cams from here....
Just had a look at the genral POI's here and I can only see download for Tom Tom? Am I missing something? What files are you loading to your I3? _________________ -----------------------------------
Enjoy? WTF?
(S)ad
(A)nd
(P)roud
Posted: Mon Dec 25, 2006 11:18 pm Post subject: |
Apologies just read:
3) We have had some reports of the POIs being incompatible with some Garmin Nuvi and i3 systems. While we are investigating this we have removed the Garmin download option.
Enjoy? WTF?
(S)ad
(A)nd
(P)roud
racman Lifetime Member
Posted: Tue Dec 26, 2006 6:38 pm Post subject: |
PGPSW Have you got a fix yet for i3 |
stupot57 Occasional Visitor
Posted: Wed Dec 27, 2006 2:30 pm Post subject: POI & i3 |
Wished I had seen this posting before applying the the new POIs My unit is totally useless. All I can do is switch it on. I have to remove the card to do a reset but when I put the card back in and try do anything it just totally freezes up on me and my only option is to turn the unit off. I am really p d off. I've tried everything I can think of but to no avail. Can anyone help please.
Stupot57 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Wed Dec 27, 2006 2:47 pm Post subject: |
you could try the beta version of poiloader as it gives you an option to remove poi's from your garmin unit.
MaFt |
