deanos Occasional Visitor
Posted: Thu Nov 23, 2006 5:35 pm Post subject: |
The ones i have end .ov2 and .bmp thats what i have been putting in the download folder on the pc , if i add them to the memory card they appear on the home software on the right hand side and it lets me delete them from the tomtom |
Shinymera Regular Visitor
Posted: Thu Nov 23, 2006 5:44 pm Post subject: |
Yep just put them in the map folder on the TomTom SD card - that all you have to do.
TomTom Home software will only recognise a .ov2 file when it is installed onto the TomTom. As you say the Home software will allow you to delete them from the unit. However for the Home software will only see toc/cab files on the pc.
Some poi's are supplied as cab/toc and Home can be used to install them. Others however are supplied as ov2 files. these are simply copied directly to the map folder on the SD card. |
Oldboy Pocket GPS Moderator
Posted: Thu Nov 23, 2006 8:34 pm Post subject: |
deanos wrote: | i dont have a folder called contents either | If you start HOME then go to File | Preferences | Advanced you can set the Extra Content Folder to point whereever you want on your Hard Drive.
This is the place to put your CAB and TOC Files, and is where HOME will look.;) _________________ Richard
Posted: Thu Nov 23, 2006 11:46 pm Post subject: |
Hi Oldboy,
I've just had a look to see what mine is set to. Sure enough the 'Extra Content' points to \my documents\tomtom\HOME\content
However that folder does not exist. Strange it wasn't created during the install. |
Posted: Fri Nov 24, 2006 8:47 am Post subject: |
Shinymera wrote: | I've just had a look to see what mine is set to. Sure enough the 'Extra Content' points to \my documents\tomtom\HOME\content
However that folder does not exist. Strange it wasn't created during the install. | It didn't create it on my PC either.
However I changed it at the first to the Folder that I use for all things TomTom! You can create the Folder manually, or do as I did.;) _________________ Richard
