Pocket GPS World :: View topic - TT510 upgrade SD card - no maps found
rotty66
PostPosted: Mon Aug 07, 2006 8:01 pm    Post subject: TT510 upgrade SD card - no maps found Reply with quote
Upgraded my TT510 to a 2gb SD card but can't get it to work , get a "no maps found" message
I have tried to methods of doing it , both by copying original card to PC and copying to new card , also tried it by using the backup/restore feature in the TT application
any ideas ?
thanks
PostPosted: Mon Aug 07, 2006 8:12 pm    Post subject: Reply with quote
Have you tried the pin-in-the-hole reset method?
ColinS
PostPosted: Mon Aug 07, 2006 9:13 pm    Post subject: Reply with quote
Does the original SD card still work?
I upgraded mine using backup and restore and that worked fine. Maybe it's the card, do you have another one you could try. Also suggest that you publish the make and model of the card just in case others are using it okay.
Colin
Honda Jazz EX-Navi MKIII
rotty66
PostPosted: Mon Aug 07, 2006 9:23 pm    Post subject: Reply with quote
thanks for the replies
yes I have tried the reset
the card is a cheapo one , says "keymem" on it
original card still works fine
ColinS
PostPosted: Mon Aug 07, 2006 9:49 pm    Post subject: Reply with quote
Well I can't see that you've done anything wrong so my guess is that the card is incompatible.
Colin
Mullet
PostPosted: Mon Aug 07, 2006 11:01 pm    Post subject: Reply with quote
rotty66
Did you format the card?
rotty66
PostPosted: Mon Aug 07, 2006 11:26 pm    Post subject: Reply with quote
Mullet wrote:
rotty66
ah , this is where we head down the rotty is a plonker line , didn;t realise I had to
will format and try again Smile
rotty66
PostPosted: Mon Aug 07, 2006 11:56 pm    Post subject: Reply with quote
seems to be working now , formatted as FAT and recopied the files
thanks for all your help folks
I will now go and find a corner to be embarrassed in :P
Mullet
PostPosted: Tue Aug 08, 2006 12:11 am    Post subject: Reply with quote
Pleased its sorted, we can all make oversights. Laughing
bigyun2000
PostPosted: Fri Aug 25, 2006 6:18 pm    Post subject: Reply with quote
Hi all
I got same problem.
I use the Kingston 512mb Elite Pro card (can't get the map to worl always wants activation. When i give it all details it fails) Original is fine.
Also tried on my Sandisk 2GB and exactly same problem.
Have formatted both in FAT
Have used the copy method and the backup/restore method Smile
Been at it about 4 hours now :x
Any please HELP !!!
Regards
Bigyun2000 UK
TOM TOM GO 530
Version 9.510 (2039, 4/4/2013) | OS: 842337 | MAP v910.4892 | iPad Mini | iPhone 5 |
bigyun2000
PostPosted: Fri Aug 25, 2006 7:24 pm    Post subject: Reply with quote
Ha sorted it out at last.
Here how i did it.
RESET
Installed TT Home
Asked me to install another required file (downloaded automatically)
Run through the setup on PC rather than unit and worked fine.
So all the setting up was done on the PC (it had a duplicate TTG 510 you can use just as the unit itself)
Only problem is now everytime i connect. I get a hugh list of speed cams to download which are not relevant for me
Any ideas on this please
Regards
Bigyun2000 UK
TOM TOM GO 530
bigyun2000
PostPosted: Fri Aug 25, 2006 7:26 pm    Post subject: Reply with quote
Your not going to believe this. As soon as i disconnect from the cradle i gotta go through it all again
Same problem as my first post :X
Regards
Bigyun2000 UK
TOM TOM GO 530
TuurG
PostPosted: Sun Aug 27, 2006 3:22 pm    Post subject: Reply with quote
contact Support about this. They have a fix available.
GO1005
MGC GT 1968
MGB Cabrio 1973
bigyun2000
PostPosted: Mon Aug 28, 2006 2:33 pm    Post subject: Reply with quote
Thanks.
It worked fine
Regards
Bigyun2000 UK
TOM TOM GO 530
