Pocket GPS World :: View topic - Well & Truly Cheased Off TTG 300 - TTG 710
bigyun2000
PostPosted: Mon Aug 07, 2006 10:49 pm    Post subject: Well & Truly Cheased Off TTG 300 - TTG 710 Reply with quote
Hi all.
I just upgraded from my TTG 300 to a new TTG 710.
Only 1 problem and want to let everyone else know and see if anyone has a solution.
When i use the TTG 300 i have a rubbish signal due to my windscreen. So i spent £50 on an external antenna for it.
Now i have the TTG 710. Still a very poor signal due to my windscreen so tried to use my original TT antenna and guess what?
The fittings for the antenna are not the same so i am unable to use my TTG 710.
Why not keep things standard. When you pay around £450 for an item and you can't use it. I think TomTom are taking the mick (was going to say something a little stronger then).
Anyone know where i can get an adaptor or something please?
Regards
Bigyun2000 UK
TOM TOM GO 530
Version 9.510 (2039, 4/4/2013) | OS: 842337 | MAP v910.4892 | iPad Mini | iPhone 5 |
MELennium
PostPosted: Mon Aug 07, 2006 11:43 pm    Post subject: Reply with quote
The 510/710/910 & the One uses the sirfstar III reciever which is not compatible with the older models.These are much more sensitive to picking up sats so your 710 should not require an external antenna even with the type of windscreen you have.
TomTom Go 910 (3) v.6.522 Map Western Europe v.650 with useless TMC receiver
Ex. owner TomTom 910 (2) Returned Faulty
Ex. owner TomTom 910 (1) Returned Faulty
Ex. owner TomTom One v.5.420 Map UK v.605
Ex. owner Garmin i3 v.2.7 Map UK V.7
bigyun2000
PostPosted: Mon Aug 07, 2006 11:45 pm    Post subject: Reply with quote
Thanks.
Will give it a much better try tomorrow.
Regards
Bigyun2000 UK
TOM TOM GO 530
TonyHoyle
PostPosted: Tue Aug 08, 2006 5:56 am    Post subject: Reply with quote
The 910 interface is changed in such a way that nothing that went before will work. It's even more devious than just changing the pinouts - the dock has a custom chip on it that does part of the processing... if you don't have that chip you can't make a dock (the pins on the connector seem to be all data apart from the audio & serial I/O - probably i2c to the on-dock processor. On the one hand it lets them do things like ipod connectors without having to add pins.. as a side effect it means a clone x10 dock is somewhere between very difficult and impossible).
22.054 (22 May 24)
