Pocket GPS World :: View topic - Garmin i3 and Rechargeable Batteries
Goto page Previous  1, 2
knuttt
PostPosted: Thu Feb 16, 2006 2:04 pm    Post subject: Reply with quote
Will test tonight (well go and sit in the car and have a play with the leads).
On the subject of battery life, you may find reducing the scren prightness helps to extend the time, think I have mine on quite a low setting and it seems pretty good.
By the way, is it me or is the unit a lot louder when on car power, more testing required I suppose.
Will report back later.
Andy
"Smoke me a kipper, I'll be back for breafast" - Arnold 'Ace' Rimmer
Pocketgps
PostPosted: Thu Feb 16, 2006 7:13 pm    Post subject: Reply with quote
I'm using some 2700mAh NI-MH's and it lasts about 7 hours before it stops.
That's with full screen brightness and vol on 5.
The batts were of eBay HERE for anybody that's interested.
Total £10 for 8, but don't forget you need a compatible charger.
andyorkney
PostPosted: Fri Mar 10, 2006 1:01 am    Post subject: option to select nimh or alkaline in menu, why? Reply with quote
Just bought the garmin i3 today and found that it has a battery type selection in the system menu, anyone know why?
I also noticed that while plugged into the Mac (with virtual PC, role on OS X support) that the 2300 NiMh batteries I've installed appeared to have more charge... suggestions?
BTW Hi folks, first post
PaulB2005
PostPosted: Fri Mar 10, 2006 1:06 am    Post subject: Reply with quote
So the battery meter can read the charge from the battery correctly.
An illusion. The i3 has no charging circuit. How did you find out they had more charge?
Pocketgps
PostPosted: Fri Mar 10, 2006 1:36 am    Post subject: Re: option to select nimh or alkaline in menu, why? Reply with quote
Welcome to the forum's .....
Standard LR6 (AA) batteries are 1.5v, but rechargeable's are only 1.2v so it uses a different resistance to measure them.
bumpkin
PostPosted: Fri Mar 10, 2006 12:41 pm    Post subject: Re: option to select nimh or alkaline in menu, why? Reply with quote
That's because the i3 is powered from the USB when it's plugged in, not the batteries.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
Page 2 of 2
22.054 (22 May 24)
