Pocket GPS World :: View topic - Medion Navigator Speed Display
creative
PostPosted: Fri Jan 27, 2006 8:03 pm    Post subject: Medion Navigator Speed Display Reply with quote
The medion Nav v5.1 says it displays the current speed of travel, however i cant see how to turn this on.
I thought i saw a screen shot of the speed in a speed limit circle in the top left of the screen.. any ideas ?
dabut
PostPosted: Fri Jan 27, 2006 8:10 pm    Post subject: Reply with quote
my advent gps400 with 5.1 shows speed in bottom right hand corner along with time and distance etc
ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6
Pocketgps
PostPosted: Fri Jan 27, 2006 8:23 pm    Post subject: Re: Medion Navigator Speed Display Reply with quote
My Navigon 5.2 software does display the circle as you discribe, but 2 things when using Navigon software, to get at the settings menu for that it has to be set on the first settings menu to Extended user, then I get additional menus:
Map information
Route information
Signpost information
Speed limit - this is the menu that i use to set the speed Warning icon
Volume
Representation
Auto Mode
Routing options
Logbook
Keypad
Itinerary
Format
GPS
TMC
Home address
Handsfree options
Product information
creative
PostPosted: Fri Jan 27, 2006 8:57 pm    Post subject: Reply with quote
mmm my 5.1 does not have the options:
I have set to extended
My unit is now a MEDION MDPNA250 / MD96800
Would the unit work on 5.2 and is it available as an update
Anyone else got a medion with the options above showing ?
On my old unit with 4.75 it used to show the speed under the est. time of arrival. This one doesnt and i would prefer the red circle speed
Hooloovoo
PostPosted: Fri Jan 27, 2006 10:42 pm    Post subject: Reply with quote
Medion Navigator doesn't have the speed limit and sign post display for some reason. It doesn't appear to be a full version of Navigon Navigator.
There is no 5.2 update yet. Version 5.2 seems to only be available for mobile phones at the moment.
I'm running 5.1 having upgraded from 4.75. Mine still shows the current speed at the bottom right, same as version 4.75.
The red circle (if it were available) shows the current speed limit, not your actual speed, so you couldn't have your current speed showing in a red circle anyway.
BigDavel
PostPosted: Fri Jan 27, 2006 11:47 pm    Post subject: Reply with quote
Silly question this .... I have a MDPPC150 and I notice that the Med Navigator says i am doing 3 mph less than the speedo. Is MN more accurate ? cheers
Hooloovoo
PostPosted: Sat Jan 28, 2006 12:16 am    Post subject: Reply with quote
In my opinion it is, yes.
The speedo must never under-read, but is allowed to read up to 10% over. So most read a little high.
When I'm doing 70mph on the motorway, the GPS says I'm only doing 65. The speedo has some calibration factor to convert wheel-speed into road-speed, whereas the GPS measures exactly how far you have travelled in the last second to calculate your speed. Of course even that reading is subject to GPS error and timing error, but I believe that would be less than the error in your speedo calibration.
22.052 (08 May 24)
