Pocket GPS World :: View topic - Route Calculation Time....
Goto page Previous  1, 2, 3, 4, 5  Next
pjpearce
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Route Calculation Time.... Reply with quote
Here's some stats. for an O2 XDA (206MHz) with TTN2 v2.24(361), GPS v2.06 and a 256Mb IntegralMemory SD card.
All road speed settings are at the default.
Land's End to John O'Groats
Calculation Time: 9m26s
Roads           : 188267
Journey Time    : 12:49:55
<br>
pjp
hollis_f
iPAQ 3970 PPC2K2 with latest ROM and SD upgrade overclocked with PHM to 472MHz.
Sandisk 256MB SD for maps.
Road speeds default.
Calculation time: 2:34
Roads: 203860
Journey Time: 13:52:25
Journey Distance: 844.0
aero
Chorlie have a look at this link, it seems you can.
Thud
At the risk of being flamed for being on the wrong forum....
iPAQ 5450 with CoPilot 4 Live
Calculation Time: 11 seconds
Distance            : 838.9 miles
Journey Time     : 15:43
georg
HP Jornada 568
128 Compact Flash
TTN v2.24 GPS v 2.06 default speed settings
From B3315 Land's End to A99 John O'Groats
Journey Dist 836.3
Calc time : 2min 10sec (two min : ten sec)
Roads : 198.908
Journey time : 14.21.30
LeakyBucket
iPaq 3850
128 Mb SD Card
Calculation Time: 6 mins 40 secs
Remember! It's much more difficult to reboot your brain.
nissemus
iPaq 2210
128Mb CF card
TTN 2.24, GPS 2.07, default speed settings
Calculation time: 1 minute 57 seconds
No. of roads: 189,908
Total distance: 820.2 miles
Journey time: 13.59.45
simkna
Toshiba e570 206mhz
Sandisk 128mb SD
TTN 2.24 GPS 2.07 default
Calc : 7:41
Distance : 838.9
Travel time : 14:37:40
Si. Time to upgrade methinks.
Parky
Ipaq 5450
128 Sandisk SD Card
TTN 2.24 GPS 2.07 default speed settings
Calculation Time 3min 40 secs
No. of roads 180,086
Total distance 812.5 miles
Journey time 13.49.15
Lost Cause
iPAQ 2210
Sagatek 256mb CF
TTN 2.24 GPS2.06
Default speed settings
Calc: 1 min 49 secs
Distance 836.1 miles
Travel Time: 13 hours 5 mins
Performed after a soft reset.
LeakyBucket
[/QUOTE]
Anyone know why Copilot is so quick?
[/QUOTE]
there many reasons why the timings would be different:
1. The maps used by CoPilot might not have the same data as TTN2 (I don't have CoPilot). If CoPilot doesn't show the same number of roads then the search could be considerably lighter.
2. The algorithm used may be very different. For example, TT appears to perform a full search, but maybe CoPilot performs a quick search that uses some comprises.
3. Even if the 2 programs have the same map and algorithm there could be a very large differences in the way they are implemented. Speed and efficiency isn't always the programmers priority: the slow correct answer is always preferable to the fast wrong answer.
HTH,
Stephen
Weighted graph searching is a difficult mathematical problem
Chorlie
Can you over clock a Dell Axim?
Chorlie
If it isn't broken, play with it some more...
Doghead
PostPosted: Sun Sep 21, 2003 1:11 pm    Post subject: Reply with quote
Stats re the initial test from Land's End to A99 John O'Groats
Dell Axim (basic 32 rom 32 ram - A00 version)
128 Mb SD Scandisk
Journey Dist: 834.7 miles
Calc time: 3min 50sec
Journey time: 14.20:20
Trucker
PostPosted: Tue Sep 23, 2003 12:21 am    Post subject: Reply with quote
Ok then folks, chew on this !!
iPAC 3970
TTN 2.22
Lexar 128mb SD
Using the original route it took 22 minutes to 97464 roads with 194.43 miles to go and at that point I got bored and binned the idea Smile
Now my speed setting are set for my truck and are:
M-way - 60
Major Road 50
secondary road 40
connecting road 30
local road 25
and destination road 20
Is this why it's taking soooooo long or is there another problem here.
My 3970 has always been slower than my wife's 3950 but she is running the default speed settings.
Any thoughts ?
Gary
Living from Layby to Layby !
View user's profile Send private message Yahoo Messenger
PostPosted: Tue Sep 23, 2003 5:42 pm    Post subject: Reply with quote
Here are some suggestions on improving the routig result. Not necessarily the calculation times... but it is worth a try.
Road type...................Speed set 1..........Speed set 2
Motorway............................60..........................60
International road...............45..........................45
Major road.........................45..........................45
Secondary road................40..........................40
Connecting road............... 33..........................35
Important local road...........37..........................35
Local road.........................30..........................30
Destination road................25..........................20
There will be some warnings regarding longer calculation times, but that's just because the numbers deviate from the defaults. I have had excellent results with set #1. Speeds are in mph
Page 3 of 5
