Pocket GPS World :: View topic - 231105 camera database update - which files for icn650?
crcoggins
PostPosted: Sat Dec 03, 2005 11:05 am    Post subject: 231105 camera database update - which files for icn650? Reply with quote
The 'Which files should i use' file that comes with the downloaded zipfile states:
"The different file types and versions are now in separate folders and below is a guide to which systems use which file type
asc files
POI-Warner utility, Navman SmartST V3, PiN100/300 SmartST V3, iCN510/635/650"
Is this correct? Am I missing a simpler way to update my icn650 POI files? Or is it a mistake? I used the csv files/other set as usual and it worked fine.
Question
asp245
PostPosted: Sat Dec 03, 2005 8:25 pm    Post subject: Reply with quote
You need the CSV Files then inside that folder the folder marked "other".
Regards
ASP
Tim Buxton
PostPosted: Sat Dec 03, 2005 11:18 pm    Post subject: Reply with quote
The .asc files will work without being edited but unfortunately they don't come in the speedzoned format. If you want speedzoned data then you'll have to use the .csv files in the \other subdirectory. You should edit them using Notepad. Open each one in turn and add a ; to the beginning of the first line.
Tim
22.053 (15 May 24)
