Pocket GPS World :: View topic - faulty icn 635
faulty icn 635
visionmaster
PostPosted: Sat Aug 20, 2005 3:23 am    Post subject: faulty icn 635 Reply with quote
:x I purchased an icn 635 a couple of monthes ago. I was quite impressed with the unit at first but i soon learned i had a problem with the unit. When its been on for a while it turns its self off, i persisted with this for a while,but was not impressed as i am a taxi driver. I contacted navman , they said it could be the power lead, so i tried a friends and its still the same. Contacted Navman again they said it sounds like the unit is shutting its self down due to an over heat protection device which is built in. I had the unit replaced and what do you know, the replacement is the same. Should i ask for my money back or ask for another unit ?. Not cheap at £499.00 so i expect something that works. Will be contacting Navman again.
Dan45
PostPosted: Wed Aug 31, 2005 3:05 am    Post subject: Reply with quote
Generally it works. I had no problems with mine whatsoever. However, sometimes it happens, as you described and can be read elsewhere in this forum:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=22400
Give it a try, exchange it with Navman.
Good luck!
Daniel
TomTom GO 1005 Live
TomTom GO 950 Live
caravanj
PostPosted: Fri Sep 23, 2005 3:48 pm    Post subject: Reply with quote
If the screen is too bright the display will go blank but you should still have voice guidance. ( according to the online manual ). So the message is only have the screen bright enough to read. I can read mine in full sunlight on a setting of 3 quarters ( I have not yet been unable to read it). Also I can hear the voice guidance over the car radio ( at a normal volume) with no difficulty.
22.053 (15 May 24)
