Pocket GPS World :: View topic - BT re receiver power up sequence?
buyrvrvvtiu
PostPosted: Sun Aug 21, 2005 7:31 pm    Post subject: BT re receiver power up sequence? Reply with quote
I've been using the Tom Tom wired receiver on my Palm for ages.
I decided I would prefer a wireless BT receiver so I can use it on foot an not have be tied to a 12v supply.
I bought onw of these from ebay
It seems to be working fine. I can connect to it with my PC every time no problem, but when I use it with Tom Tom 4.4 and my Palm T3 It wouldn't work.
After nearly throwing my T3 at a brick wall I have discovered a sequence that will work time after time.
It is a pain in the neck having to do this EVERY time I want to use it, but at least I know it will work.
1) Make sure the Receiver is NOT a trusted device. (If it is then delete it)
2) Switch on receiver so it is in discoverable mode
3) Add it as a trusted device on the T3 and enter pairing code when asked.
4) Run TomTom. After a few seconds the blue BT LED goes steady indicating a connection and the Tom Tom screen changes colour showing a valid GPS signal.
If I switch off the T3 then come back later I have to go through this whole procedure again otherwise I cannot connect.
Do people with other BT GPS receivers have this same problem with the T3 and TomTom 4.4?
22.052 (08 May 24)
