Pocket GPS World :: View topic - John cleese voice disapears
jas13272
PostPosted: Tue Aug 16, 2005 7:47 pm    Post subject: John cleese voice disapears Reply with quote
Hi fellas,i seem to be having a really odd problem with the cleese voice download.
all works ok until i exit application and turn the pc off(ipaq1710).then when i use ttn5 again i have to reselct the voice. as it says no usable voice selected.it only does it with this particular voice,the standard ones are ok.it reallyis a pain in the arse and tomtom support aren't the slightly bit interested.
what do i do.
please help cheers jason
jas13272
PostPosted: Thu Aug 18, 2005 11:09 am    Post subject: Reply with quote
anyone help
tinapatra
PostPosted: Thu Aug 18, 2005 5:43 pm    Post subject: Reply with quote
Both my husband and I have the same problem.
I have the upgrade and he has the full new TT5 and the same happens to both of us.
Please help us if you can.
Best regards
Best wishes
Tina
Samsung Galaxy Tab S 8.4
CoPilot Live 9
Masked-Marauder
PostPosted: Fri Aug 19, 2005 4:07 pm    Post subject: Reply with quote
did you download the voice direct from TomTom? If so you may find it has stored it in a folder on the PDA called "Voices" where as the others perhaps are on the SD card, also in a folder called "Voices"
If this is the case copy the downloaded voice to the SD card folder.
raptorheli2
PostPosted: Sat Aug 20, 2005 10:44 am    Post subject: Reply with quote
i have the same problem with all my add on voices.
there must be a reason.
cheers
adamf
PostPosted: Sat Aug 20, 2005 2:58 pm    Post subject: Reply with quote
same here its on my sd card under voices all my othe ones work fine celeb ones but its sadly its got to go its rather crap any way Laughing three times it says the long arival thing as i arive home (you have reached your destination you may get out now but i am not going to help you carry your bags from now on your on your own) Wow what a long sentence i much prefer ozzy ozborne (You have reached your F*****G destination) much shorter and funnier and it DONT remove itself Laughing Laughing Laughing Laughing Laughing Laughing Laughing
stevei
PostPosted: Sun Aug 21, 2005 10:07 pm    Post subject: Reply with quote
I have just found the solution.
Find the files on your PDA
DATA100.CHK
DATA100.VIF
Rename the number part of the file name to any two digit number using the same number for each file. Choose one that is not in the same directory.
Obviously TT5 can't cope with three digit numbers.
Steve I
Royston
PostPosted: Sun Aug 21, 2005 10:35 pm    Post subject: Reply with quote
DATA100.CHK
DATA100.VIF
Well Done!!
jas13272
PostPosted: Mon Aug 22, 2005 9:37 am    Post subject: Reply with quote
DATA100.CHK
DATA100.VIF
Nice One
Masked-Marauder
PostPosted: Mon Aug 22, 2005 2:30 pm    Post subject: Reply with quote
DATA100.CHK
DATA100.VIF
Well done in finding the solution, but a three digit number works fine on my XDAIIi. Unfortunately TomTom does not....
tinapatra
PostPosted: Mon Aug 22, 2005 3:33 pm    Post subject: Reply with quote
I have changed the .CHK and .BMP files but I don't seem to have a .VIF one.
Does this matter?
I look forward to hearing from someone.
Best wishes
Tina
CoPilot Live 9
stevei
PostPosted: Mon Aug 22, 2005 6:51 pm    Post subject: Reply with quote
I think the .VIF file has somthing to do with idetifying the .BMP file and will only have an effect on the way it is displayed in the change voice screen. The important one is the .CHK file, that has all the anouncments in it.
Steve I
PostPosted: Mon Aug 22, 2005 8:47 pm    Post subject: Reply with quote
Great fix Stevei, finally got it to work in a reliable way - thanks alot - mike
an2ony17
PostPosted: Mon Aug 22, 2005 9:11 pm    Post subject: Reply with quote
Fantatstic, its a first an correct answer found before I posted with the question?????
Nice one. :D
adamf
PostPosted: Tue Aug 23, 2005 10:54 am    Post subject: Reply with quote
dam that means i can use him again oh no Laughing Laughing
