Pocket GPS World :: View topic - Which Sirf III receiver should I buy?
OM3
PostPosted: Thu Aug 11, 2005 12:21 pm    Post subject: Which Sirf III receiver should I buy? Reply with quote
I'm confused about what Sirf III receiver I should buy.
I'm looking at www.globalpositioningsystems.co.uk.
ALL the receivers are priced the same!
The coices I have are:
- Fortuna: Slim Bluetooth GPS receiver (SiRF Star III chip)
- Holux: GPSlim236 Wireless GPS receiver (SiRF Star III Chipset)
- SysOnChip: Smart Blue mini (SiRF Star III)
- Leadtek: Bluetooth GPS (SiRF Star III)
I'd like to know which people would recommend above others.
At the moment, my choice has to be the Fortuna.
The Fortuna comes with a dual power lead, which means I can use this to power my PDA in the car.
Do any of the other units come with the same?
Thanks.
OM
OM3
PostPosted: Thu Aug 11, 2005 12:24 pm    Post subject: Problems with the Fortuna dual power cable. Reply with quote
I've got the older Fortuna clip on.
It comes with a dual charger cable that means I can charge my PDA as well.
(You need to have the right adapter for the PDA.)
This is really convenient.
Only one problem though: it doesn't charge both the PDA and GPS receiver at the same time when both are connected.
For me... this defeats the purpose of having the dual charger.
Is it supposed to be like this?
Thanks.
OM
OM3
PostPosted: Thu Aug 11, 2005 12:25 pm    Post subject: Reply with quote
ooops... sorry... that was supposed to be another post!
MarkHewitt
PostPosted: Thu Aug 11, 2005 4:29 pm    Post subject: Reply with quote
I haven't used the others but I've found the TomTom unit to be excellent.
No problems getting a fix, it's light as a feather and fits in my pocket easily.
I haven't managed to run it out of power yet either, despite some 6+ hour journeys.
OM3
PostPosted: Thu Aug 11, 2005 4:35 pm    Post subject: Reply with quote
does the tomtom have a seperate battery?
that was one of the criticisms of the old one.
MarkHewitt
PostPosted: Thu Aug 11, 2005 4:37 pm    Post subject: Reply with quote
Not that I'm aware of. There are no obvious openings to remove the battery.
Do you regard a seperate battery as a good or a bad thing?
OM3
PostPosted: Thu Aug 11, 2005 5:11 pm    Post subject: Reply with quote
well... yes.
having read and researched on this website, i believe i'm right in saying that a seperate battery is better.
if ur tomtom units battery dies, then the unti dies.
for others, if the bettery malfunctions, then u can replace the battery very easily.
i would add that tomtom (for the older model anyway) receiver there's been several people grumbling because their unit has died after one year and one day (outside of guarantee).
MarkHewitt
PostPosted: Fri Aug 12, 2005 9:44 am    Post subject: Reply with quote
OM3 wrote:
well... yes.
Yes I see your point. However personally I wouldn't let that influence me on which receiver I buy. I would rank battery life, size, weight, charge time, all above the battery issue, even if we assume the receiption of all units is identical.
SimonCatlin
PostPosted: Fri Aug 12, 2005 12:33 pm    Post subject: Reply with quote
I notice you did not mention the GlobalSat BT-338.
Any reason why?
iPhone5, TomTom, Google maps, Navfree, Viewranger and Apple Maps (ekk)
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
barleymo
PostPosted: Fri Aug 12, 2005 11:56 pm    Post subject: Reply with quote
Although I know that some users have had problems with the Globalsat BT-338 and getting it to talk to TTN5. I had no problems with mine, and the 15hr battery life makes it an excellent buy. The Fortuna slim while a bit cheaper only has an 8.5hr battery and is only slightly smaller.
bwgames
PostPosted: Sun Aug 14, 2005 7:38 pm    Post subject: Reply with quote
Happened to me, fortunately it was on the very last day of warranty.
Still not good Sad
PostPosted: Tue Aug 16, 2005 11:22 pm    Post subject: Reply with quote
Nothing can withstand our curiosity. I've opened it, and the battery in ther is a standard type that can be replaced if necessary. But certainly not while you are out, it's more in case it runs flat.
MarkHewitt
PostPosted: Wed Aug 17, 2005 9:11 am    Post subject: Reply with quote
Can you tell us what the battery type is, and where we could get replacements, just for future reference!
PostPosted: Wed Aug 17, 2005 4:13 pm    Post subject: Reply with quote
bwgames
PostPosted: Wed Aug 17, 2005 5:05 pm    Post subject: Reply with quote
I'm interested in the same as the OP, am looking for a new GPS receiver with faster TTFF (or whatever it is, for fix time)...
The BT-338 seems to be quite well used, any opinions?
