Pocket GPS World :: View topic - Tom Tom 5 maps will not load
mikeeee
PostPosted: Fri Aug 05, 2005 7:48 pm    Post subject: Tom Tom 5 maps will not load Reply with quote
I have used a Mitac with tt3 for the last 6 months with no snags. However when upgrading to ttn5 I can load the software, however when I insert the maps CD I get a message "not enough free space on temproary folder - cannot run setup"
It does not seem to be a PC problem as I can run and install the maps from ttn3. The temporary folder exists on the pda, and is empty. However the software does not seem to notice this.
I have ditched everything on the pda and started from scratch, however the same problem keeps coming up.
If anyone out there can help I would really appreciate it.
Mikeeee
PostPosted: Fri Aug 05, 2005 8:09 pm    Post subject: Reply with quote
Use a card reader to load the maps - its much faster and then you can select the exact directory you want the map to install to - you have probably by accident tried to install in excess of 100MB of map to a device that has far less memory than that required - mike
SRS
PostPosted: Fri Aug 05, 2005 9:32 pm    Post subject: Reply with quote
This is actually a known problem with TTN5. Their suggested workaround is to copy the entire contents of the CD into a folder on your Hard Disk and then run setup from there. Smile
I think they try to use the current folder as temporary space and of course that doesn't work too well on a CD-ROM. Wink
Slider.
HTC TyTN II Windows Mobile 6
TomTom Navigator 7.450(9028)
UK & ROI Map V720.1802
mikeeee
PostPosted: Sat Aug 06, 2005 9:37 am    Post subject: Reply with quote
Slider,
Thanks for your advice. I will give it a go.
Mikeeee Laughing
g0avo
PostPosted: Sat Aug 06, 2005 2:18 pm    Post subject: TomTOm Not enough space in temp folder cannot run set-up Reply with quote
This is a common problem - if you go to the TomTom sight it will tell you how to remedy this problem - It is VERY easy to fix.
I had the same problem myself and could not find a solution on this forum.
Paul g0avo
http://www.tomtom.com/3239
g0avo
PostPosted: Sat Aug 06, 2005 2:24 pm    Post subject: TomTOm Not enough space in temp folder cannot run set-up Reply with quote
This is a common problem - if you go to the TomTom siite it will tell you how to remedy this problem - It is VERY easy to fix.
Paul g0avo
mikeeee
PostPosted: Sat Aug 06, 2005 6:42 pm    Post subject: Reply with quote
Guys,
Thanks for your help, Slider was right and I now have the system up and running, if only I could sort on those POIs.......
Thanks to all
Mikeeee :D
PostPosted: Sat Aug 06, 2005 7:23 pm    Post subject: Reply with quote
Whats the problem you are experiancing with the POI - give more details and no doubt there will be help avail - Mike
jeff261159
PostPosted: Mon Aug 08, 2005 3:31 pm    Post subject: Installation Error Reply with quote
The easiest way to get round this is remove the cd from the drive, then go to 'run' then type in %temp% delete the 'setup' file (tomtom) from this list using the delete button on your keyboard, once done you will be able to install the maps.
mburton2
PostPosted: Wed Aug 10, 2005 11:06 am    Post subject: Re: Installation Error Reply with quote
I was JUST about to suggest that!........Worked for me! Thumbs Up
