Pocket GPS World :: View topic - TT5 CRASHES TO TODAY SCREEN WHEN BROWSING MAP
sdreiter
PostPosted: Fri Jul 08, 2005 11:44 am    Post subject: TT5 CRASHES TO TODAY SCREEN WHEN BROWSING MAP Reply with quote
WHENEVER I PRESS THE BROWSE MAP OPTION T5 CRASGES STRAIGHT AWAY TO THE TODAY SCREEN.
VERY ANNOYING
CAN ANYONE HELP?
linknet
PostPosted: Fri Jul 08, 2005 12:12 pm    Post subject: Reply with quote
This could be the "No POI found" or crash to Today screen bug.
Try Change preferences...Manage POI...Enable/Disable POI and uncheck all the built in POI's. Then try browsing the map again.
Roger
sdreiter
PostPosted: Fri Jul 08, 2005 12:50 pm    Post subject: Reply with quote
Is there a fix for this, or can the software just no tseal with all the POI.
Does this mean you have to keep enable/disabling them when you switch between 3D mode and the map view?
what a pain in the backside!
linknet
PostPosted: Fri Jul 08, 2005 12:58 pm    Post subject: Reply with quote
I presume that worked?
A partial solution is to use the TTN3 poi.dat file. See related topics.
I you re-enable them for 3D you may experience crashes whilst navigating.
Roger
sdreiter
PostPosted: Fri Jul 08, 2005 1:08 pm    Post subject: Reply with quote
YEAH THAT WORKED THANKS
WHERE DO I GET THE TTN3 poi.dat file TT5 is the first nav software I've had.
what will it do?
does all this mean i have to disable the speed cameras to browse the map then enable them when navigating?
linknet
PostPosted: Fri Jul 08, 2005 1:17 pm    Post subject: Reply with quote
This only applies to the built in POI's. The user POI's such as speed cameras work fine and can be enabled.
Unless you install the TTN3 poi.dat file you need to leave the built in POI's disabled all the time or you may still experience crashes.
I'm afraid I can't help with the TTN3.0 or TTN4.4 poi.dat file. Hopefully TomTom will provide a fix for this soon!!!!
Roger
