Pocket GPS World :: View topic - Maps of greece
Maps of greece
zeus68
PostPosted: Mon Jul 04, 2005 7:42 pm    Post subject: Maps of greece Reply with quote
I have a copy of Destinator 3.075 but the only maps of greece I have are quite old, version 2004 Q2 2405 I beleive there's a new version of the map which hopefully covers a lot more than the existing one I have. Anyone has the current maps?
MarkH
PostPosted: Sun Jul 17, 2005 12:54 am    Post subject: Reply with quote
I've just ordered it from a Greek online shop but I think you can download updated maps from here http://www.ngi.gr/page.php?pageid=44&languageid=1
zeus68
PostPosted: Sun Jul 17, 2005 3:13 pm    Post subject: Reply with quote
I would if I had an original copy of destinator or a valid account. I have downloaded destinator 3 from the net.
MarkH
PostPosted: Sun Aug 14, 2005 6:20 pm    Post subject: Reply with quote
Just a comment on the NGI map of Greece - it's pretty good in cities like Athens or Hania on Crete. It also shows ferry routes between islands. But on the islands e.g. Santorini, it doesn't show all roads - less than what you will find in the Lonely Planet guide book maps. And the roads it does show none of them are named. Though it does show the name of villages on the island.
MarkH
PostPosted: Sun Aug 14, 2005 6:23 pm    Post subject: Reply with quote
I would also like to add that Destinator 3 only seems to support car routing. So if you are walking around Athens the routing funtionality isn't much use.
ssarl
PostPosted: Mon Aug 15, 2005 12:09 pm    Post subject: Reply with quote
Yes but the new Destinator PN supports Pedestrian mode. :D
MarkH
PostPosted: Mon Aug 15, 2005 2:31 pm    Post subject: Reply with quote
Thats good to know. Would you know if the D3 maps will work with PN? The NGI Greek map seems only to be available for D3.
ssarl
PostPosted: Mon Aug 15, 2005 3:53 pm    Post subject: Reply with quote
I'm currently make a beta test of Destinator PN with maps of Greece from NGI. The map will be available with the "Destinator PN Greece" up to the end of Semptember. Actually the map is the same with Destinator 3, but you have to reactivate due to the different device id Destinator Pn uses. As far as I know with 70E you will be able to upgrade from Destinator 3 to Destinator PN (maps of NGI). Regular updates of maps can download from: www.ngi.gr .
The new Destinator PN has also a map of Greece from NavTeq but this map is not up-to-date and covers only Attica.
TheRock
PostPosted: Wed Aug 24, 2005 9:35 pm    Post subject: Reply with quote
Hi:
To activate D3 maps in PN do this:
- remove DestinatorPN
- install Destinator3 and activate software and maps
- install DestinatorPN on top
- go to folder \My Documents\HSTC\Destinator and rename file
licensep.txt into licenses.txt
Rock
dominion666
PostPosted: Mon Aug 29, 2005 10:34 am    Post subject: Reply with quote
Hello,
I have the same problem.
Anybody can share the lastest map in english please ?
Thanks !
