Pocket GPS World :: View topic - can the windscreen stop the reciever from working correctly?
2seconds
PostPosted: Thu May 19, 2005 6:36 pm    Post subject: can the windscreen stop the reciever from working correctly? Reply with quote
i seem to loose connection quite a lot and i have just had a new windscreen put in and talking to the installer he recons that is has got a sun screen built in to stop the sun rays getting in and this stops the satalite connecting?
Is this true if so how can i over come this, i have a bluetooth gps reciever.
thanks in advanced
Pocketgps
PostPosted: Thu May 19, 2005 6:43 pm    Post subject: Reply with quote
Heated windscreens found for instance on the Ford Focus and Mondeo, do not effect the performance of a GPS system. Please bear in mind however that the new Renault Laguna and Scenic and the Citreon C5 and Picasso (plus others makes coming on the market) may come as standard with a metalacised 'Heat reflective' windscreen which will (can) prevent any GPS unit from operating correctly. If you do have a vehicle with this type of screen fitted you should probably consider installing the GPS antenna in the back window of the vehicle, thus illiminating the heat reflective glass.
2seconds
PostPosted: Thu May 19, 2005 6:46 pm    Post subject: Reply with quote
i think that i have got one of these screens as ive tried 2 differant recievers now, and still get the same problem.
i know i wrote car but it is a van that its in so how can i get round this? is there an external aerial i can get?
Robin2
PostPosted: Thu May 19, 2005 7:41 pm    Post subject: Reply with quote
Often there is a small patch at the edge of the screen where there is no reflective layer. It's worth moving your receiver to the corner of the screen to see if you can get a signal
Robin
2seconds
PostPosted: Thu May 19, 2005 7:43 pm    Post subject: Reply with quote
Cheers Robin2 its worth a try
22.053 (15 May 24)
