Pocket GPS World :: View topic - Replacement batteries
cherokee3
PostPosted: Mon May 04, 2009 4:48 pm    Post subject: Replacement batteries Reply with quote
I got the SATMAP Li-ion rechargable + attachments last year. Its worked really well. Had a little damp problem when I had it out in the rain for 3 days but it was easy to correct. However it stopped working yesterday and on removing the back cover I find the red wire has become detached. Does anyone know how to get hold of just the battery as I don't need the other stuff?
PostPosted: Mon May 04, 2009 5:29 pm    Post subject: Reply with quote
Welcome to the forum, contact Satmap by phone in the morning 0845 873 0101 they should be able to resolve this issue - Mike
cherokee3
PostPosted: Mon May 04, 2009 6:52 pm    Post subject: Reply with quote
Thanks Mike
mapguy
PostPosted: Sun Jun 07, 2009 11:06 pm    Post subject: Reply with quote
cherokee3 - what was the outcome of your call to Satmap? I had exactly the same thing happen today whilst out on the bike: unit simply stopped working and, on investigation, the red wire has snapped off at the battery casing.
mapguy
PostPosted: Fri Jun 12, 2009 6:52 am    Post subject: Reply with quote
I'll answer my own question! I contacted Satmap; they asked me to return the faulty battery; I sent it on Tuesday and had a new battery in the post on Thursday morning.
A1 customer service - very impressed - thanks guys.
grettonhillbilly
PostPosted: Sat Jun 20, 2009 6:43 am    Post subject: changing batteries Reply with quote
I use rechargeable AA batteries whihc I swap over when they start to get low. The problem is that the unit understandably turns off. I thought I could solve this by buying a cheap mobile phone power pack and using this to provide power in the change over. But this doesn't work. Even if the unit is connected to my PC during a battery swap it goes into lower power mode and insists on turning off even if the batteries are only out for a few seconds. ANy thoughts? is this to do woth the amount of power from the PC/external pack or a basic problem with the unit
grettonhillbilly
PostPosted: Sat Jun 20, 2009 6:44 am    Post subject: changing batteries Reply with quote
I use rechargeable AA batteries whihc I swap over when they start to get low. The problem is that the unit understandably turns off. I thought I could solve this by buying a cheap mobile phone power pack and using this to provide power in the change over. But this doesn't work. Even if the unit is connected to my PC during a battery swap it goes into lower power mode and insists on turning off even if the batteries are only out for a few seconds. Any thoughts? is this to do with the amount of power from the PC/external pack or a basic problem with the unit
PostPosted: Sat Jun 20, 2009 8:08 am    Post subject: Reply with quote
Welcome to the forum, the behaviour your device is doing is normal, it isn't possible to keep the device on when swapping out batteries - Mike
22.044 (24 Apr 24)
