Pocket GPS World :: View topic - Disable Auto Shutdown via USB/PC?
Graeme2812
PostPosted: Mon Apr 05, 2010 7:19 pm    Post subject: Disable Auto Shutdown via USB/PC? Reply with quote
Is it possible to dissable the auto power down process that my 550 has when it is connected to my PC?
The reason I ask is that I have a USB port in my car and it will be much more convient and tidy if i can plug my TomTom in via the USB port rather than the Aux socket. I have tried plugging the device in on the car's USB port and it continues to power (well, power LED lights up) but it automaticly shuts down everytime after a few min.
Can't see anything in the device settings, does anyone have any ideas?
Thanks,
Graeme
Graeme Bennett
Go 540 LIVE
App. 9.510.1234792.1 (2039,04/04/2013)
United Kingdom & ROI v945.6174
PostPosted: Mon Apr 05, 2010 8:03 pm    Post subject: Reply with quote
Use Notepad to create a new file with just a "1" in it (without the "") save the file as "noautosuspend.dat" then copy it straight to the device (no "" in the file name), drop the file straight on to the drive letter associated with your device using Windows Explorer - Mike
253
PostPosted: Mon Apr 05, 2010 8:50 pm    Post subject: Reply with quote
Well !!, thanks for that Mike.
Been something that's been bugging me as well, but never thought to ask Sad
Thought it was a 'given' so to speak.
Will it work with my TT720??
Cheers Bob
PostPosted: Mon Apr 05, 2010 9:17 pm    Post subject: Reply with quote
Bob, it works fine on a 720 as thats the device I first started using this "fix" on - Mike
AliOnHols
PostPosted: Tue Apr 06, 2010 9:58 am    Post subject: Reply with quote
think we need to change your name to MikeTheHero! This has been bugging me for the last year also, but not any more. Cool
Garmin Nuvi 2599
SatMap Active 10 & 20.
jonial
PostPosted: Tue Apr 06, 2010 10:14 am    Post subject: Reply with quote
Mike
Many thanks indeed for this tip
John
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
Graeme2812
PostPosted: Tue Apr 06, 2010 8:03 pm    Post subject: Reply with quote
Thanks verymuch again Mike.
Works a treat.
Graeme Bennett
Go 540 LIVE
jonial
PostPosted: Fri Apr 09, 2010 1:20 pm    Post subject: Reply with quote
I know this is the wrong title ,but here goes:-
Is there a similar software instruction to turn the Go720 on when power is connected via the usb connector?
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Fri Apr 09, 2010 4:47 pm    Post subject: Reply with quote
The Go-x10 devices certainly did this but due to issues with the mount TomTom removed the auto power on/ off and despite many requests to reinstate this functionality on the newer products they don't listen - Nobody has found a hack/ work around to enable it either so I am afraid you are stuck with it - Mike
jonial
PostPosted: Fri Apr 09, 2010 5:20 pm    Post subject: Reply with quote
Hi Mike
Thanks for the answer, which was as I expected.
I did have a G0710 and I can't now remember quite how it was done but you could get the Go to turn on and off with the ignition which was very useful.
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Fri Apr 09, 2010 5:46 pm    Post subject: Reply with quote
With a 710 you would need a Navcore release prior to 6,51 to get the auto on/ off working again, once 6,51 was rolled out which was needed for the FM Transmitter mount and RDS-TMC receiver support the auto on feature disapeared and hasn't been seen since! (I do still have a couple of 910 Navcores on this PC that are pre 6,51 but no 910 to run it on as it burnt out) - Mike
Oldboy
PostPosted: Fri Apr 09, 2010 6:17 pm    Post subject: Reply with quote
The latest 910 software still supports the auto on/off function on the standard mount. (v7.903).
22.053 (15 May 24)
