Pocket GPS World :: View topic - No signal under trees?
mud_dodger
PostPosted: Mon Dec 08, 2008 11:26 pm    Post subject: No signal under trees? Reply with quote
Hi all,
I have a Garmin Legend Etrex which I mainly use with Memory Map for Mountain biking. The problem I have is a lot of the Biking I do is in the woods and I tend to lose signal and orientation frequently. Is that typical? Would my problems be solved with a new generation GPS?
I am considering buying either a Satmap or Garmin Oregon. Would either be better then what I currently have? Does the Oregon have the same chipset (satelite sensitivity) as the Etrex I already have?
Thanks in advance!
Brett
Green_ninja
PostPosted: Tue Dec 09, 2008 5:13 pm    Post subject: Reply with quote
it's not unusual to lose th satellites in heavily wooded areas (also in areas with lots of skyscrapers) a lot depends on the chipset used/ later ones like sirf111 are more sensitive
philpugh
PostPosted: Thu Dec 11, 2008 4:59 pm    Post subject: Reply with quote
Can't speak for the units you are looking at but my Garmin Colorado 300 is significantly more sensitive than my older Garmin GPS60. I would expect the Oregon to be similar. However very wet, very leafy forests are a good challenge for any hand held receiver!
Phil
22.044 (24 Apr 24)
