NO_MAD Lifetime Member
Joined: Mar 02, 2006 Posts: 71 Location: St Albans Herts
Posted: Sat May 16, 2009 6:53 pm Post subject: TT720 talk to a Parrot |
Hi All
Have just got a Parrot fitted in my van.
Can i get my TT720 to link up to my Parrot so that i can get the tt voice out of my radio?
NO_MAD |
Posted: Sat May 16, 2009 7:24 pm Post subject: |
What Bluetooth profiles does the Parrot support, it needs to offer an A2DP profile for it to work, see if thats mentioned in the manual or on the box - Mike |
Rick-uk Lifetime Member
Joined: Apr 16, 2006 Posts: 320 Location: BS20, North Somerset
Posted: Sat May 16, 2009 10:49 pm Post subject: |
there is a thread here where user jimbo_hippo had some success with his TT and Parrot
I have a 520 and Mk6100 and have had limited success getting the two to operate consistantly and in a reliable manner.
I have given up trying just now. |
Posted: Sun May 17, 2009 12:02 pm Post subject: |
Hi Mike
Yes the parrot dose have the A2DP profile
NO_MAD |
Posted: Sun May 17, 2009 1:00 pm Post subject: |
In that case make sure the Parrot is ready to receive a Bluetooth connection, on the TomTom make sure Bluetooth is enabled from within the Change Preferences options, then go to Change Preferences/ Speaker Preferences and set the unit to play nav instructions via its own speaker and music via Bluetooth, this gives you the option not to pause the music when nav instructions are issued. Note it will probably only start the BT connection to the Parrot when you select an mp3 track to play.
Go through the pairing process, if the Go doesn't find the Parrot there is a Bluetooth fix that can be applied to the 720 that will make it see far more Bluetooth devices, but for a start I would try and get it working without the BT Fix - Mike |
Posted: Sun May 17, 2009 4:06 pm Post subject: |
TT can see the parrot And the parrot can see the TT but will not pair.
NO_MAD |
