adamwolfe Lifetime Member
Joined: Apr 26, 2007 Posts: 101 Location: Scottish Borders
Posted: Tue May 13, 2008 6:34 pm Post subject: Tomtom Camera Button |
Hi All
I am now using the PGPS camera database and no longer subscribe to the Tomtom offering. I forgot to remove the "new camera/remove camera" from the main screen. The option to remove it is greyed out because I no longer have access to their camera database. Is there any way to remove the button from the screen or am I stuck with it?
Any help much appreciated.
Thanks _________________ Adam |
Posted: Thu May 15, 2008 3:23 pm Post subject: Re: Tomtom Camera Button |
adamwolfe wrote: | Hi All
Thanks |
Anybody.......... _________________ Adam |
Darren Frequent Visitor
Posted: Thu May 15, 2008 3:47 pm Post subject: |
Where does it appear, on the map display? If so, can you disable it in QuickMenu? _________________ Darren Griffin |
Posted: Thu May 15, 2008 3:57 pm Post subject: |
Hi Darren - thanks for your reply.
The "button" in question appears on the lhs of the map screen. It is added or removed by following the Tomtom PLUS services - Safety Camera Warnings. The option to enable/disable is the bottom rhs button. This is the page that is now greyed out as my Tomtomsubscription has finished. I have a feeling that I'm stuck with it. _________________ Adam |
Posted: Thu May 15, 2008 4:44 pm Post subject: |
Ah I see. I don't use their cameras as you'd expect. There must be a way of disabling this, have you tried a reset? _________________ Darren Griffin |
Posted: Thu May 15, 2008 4:48 pm Post subject: |
Darren wrote: | Ah I see. I don't use their cameras as you'd expect. There must be a way of disabling this, have you tried a reset? |
Sorry to be dim but do you mean the phone or....... _________________ Adam |
Posted: Thu May 15, 2008 4:52 pm Post subject: |
adamwolfe wrote: | Sorry to be dim but do you mean the phone or....... |
Phone? who mentioned a phone No I was referring to the TomTom. I assumed you had a GO device, what do you have? _________________ Darren Griffin |
Posted: Thu May 15, 2008 4:54 pm Post subject: |
Quote: | Phone? who mentioned a phone |
look at adamwolfe's sig.... |
Posted: Thu May 15, 2008 5:00 pm Post subject: |
PaulB2005 wrote: | look at adamwolfe's sig.... |
Oh gawd Could it have been more obvious! Sorry Adam!
In which case there is always the option of a re-install I suppose but I appreciate it's a sledgehammer to crack a nut!
One other idea, take a backup of 'mapsettings.cfg' in your map folder and save it to the PC or a folder on your SPV's storage card. Then delete the original .cfg file and re-start TomTom. Does the button disappear then? if not exit TomTom and copy the original file back.
Doing this will require you to re-input your cam warnings settings though so it's a trade off as to how annoying the defunct button is.
However if you wait a while, MikeA will be on the forums later and I'll bet he knows the solution if one exists! _________________ Darren Griffin |
Posted: Thu May 15, 2008 5:08 pm Post subject: |
Darren wrote: | PaulB2005 wrote: | look at adamwolfe's sig.... |
However if you wait a while, MikeA will be on the forums later and I'll bet he knows the solution if one exists! |
PaulB2005s quick isn't he no solutions though Considering how many posts you answer we'll say no more. Your solution is worth a try but I think I'll wait to see if MikeA can come up with anything as well. I do appreciate your input though
regards _________________ Adam |
Posted: Thu May 15, 2008 5:53 pm Post subject: |
Pure guess, as I don't use the speed cameras from TomTom other than for a giggle from time to time, try removing the speed camera POI files from your map folder, if there are no files it might not warn about them, or offer a short cut to them as they will no longer exist.
There is some information on how to remove the Speed Camera files on the TomTom web site see Here
If the above doesn't help I would try Darrens suggestion of removal of the MapSettings.cfg file from the map folder, if that fails re-install the application to the device - Mike |
Posted: Tue May 20, 2008 10:19 am Post subject: |
Many Thanks to all replies. I sorted this by accident. I was sitting waiting for my ferry back to Scotland and fiddling with the Nav software and noticed I could download POI direct from Tomtom. Following the menu I arrived at Safety Cameras for UK. Thinking I wouldn't be able to, re subscription finished, I managed to download the cameras. When Navigator had finished whinging about my subscription, the cameras appeared, along with all the greyed out options being activated again. I removed the button from the map screen and am now a happy bunny.
Also managed to report a possible new specs site in Northern Ireland and now appearing on the submission map. I may or may not qualify for lifetime membership but the submission system certainly works ie blue squares on my map page!
Cheers All _________________ Adam |
