Pocket GPS World :: View topic - GPS Viewing Applications
Leenig
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: GPS Viewing Applications Reply with quote
Available for download on the Navman site along side SP2 is something called GPS Viewing Applications for iPAQ –what is this?
Lee
onbashi
I think this is called gps info, it's a small prog that can be used to view information being received from the gps receiver including the amount of sats that its locked to, I believe that it tells you what version sleeve your using as well(if you use a sleeve that is)
if you use it be careful because you can adjust things that can upset the receiver which will require leaving it off for some time to reset itself to the factory defaults, I think this is right, but dont quote me on it!
Good luck...
In The Land Of The Blind The One Eyed Man Is King!
22.053 (15 May 24)
