Pocket GPS World :: View topic - 5 to 5.1 on XDA2i
5 to 5.1 on XDA2i
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navigon Handhelds
I_Need_Help
PostPosted: Tue Aug 16, 2005 11:15 pm    Post subject: 5 to 5.1 on XDA2i Reply with quote
I'm trying to upgrade from 5 to 5.1 on my xda but its not working I copy over the cab MN51_Update_WM2003.cab try runing it, I get an install box come up and the go (no blue progress bars) and then it states I should restart the system which I do but it still on the old version!
Is it because its wm2003 se phone edition? or have i missed something.
I have tried runing it from the temp folder as they say and the memory card Sad
alix776
PostPosted: Wed Aug 17, 2005 8:42 am    Post subject: Reply with quote
whilst tomtom set up is running remove the xda from the crade and soft reset allow to boot up then replace the xda in the cradle sounds daft but it works
device Lumia 950 xl
I_Need_Help
PostPosted: Wed Aug 17, 2005 12:31 pm    Post subject: Reply with quote
I was doubtful about this advice especially as it referenced tomtom and this Navigon (which one is better?Smile ) however, I started the install and as soon as the box disappeared I soft reset the device, the result was that Navigon has gone! Well the shortcut has, running the program from the directory it works and shows as V5.1.
Well adding the shortcut back should be simple enough to it’s a success.
Thanks you for your help.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navigon Handhelds All times are GMT + 1 Hour
22.044 (24 Apr 24)
