brianleach Occasional Visitor
Joined: Sep 06, 2004 Posts: 36 Location: Winchester, Hants
Posted: Mon Aug 01, 2005 12:39 pm Post subject: Flight Mode |
Can anyone tell me what the hell Flight Mode means on the change preferences page and should I get rid of it?
If so how?
Many thanks.
Brian Leach |
alix776 Pocket GPS Moderator
Posted: Mon Aug 01, 2005 2:59 pm Post subject: |
if your using an xda or one the other devices from orange or vodaphone then flight mode turns all the conections off so the device can be taken on to a plane
what device are you using pls and could you pls update you profile to let us know what country your in as software and hardware can vairy between countries and the forum users can then give better answers to you questions _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Aug 01, 2005 3:30 pm Post subject: Flight Mode |
Thank you for the information.
I have updated my profile.
I am using an XDA II, TT5.1 and a GLOBALSAT BT308 BLUETOOTH GPS RECEIVER
I have never seen Flight Mode before and I can't recall whether it appeared before or after the 5.1 upgrade.
Is it helpful or should I disable it and if so how please.
Many thanks,
Brian Leach |
xda Lifetime Member
Posted: Mon Aug 01, 2005 3:45 pm Post subject: |
Flight mode is part of the XDA II installation, it is the same as turning off a mobile phone when boarding an aircraft except in the case of the XDA it still leaves the PPC part of the unit working. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Mon Aug 01, 2005 3:50 pm Post subject: Flight Mode |
However I don't know how I turned on the Flight Mode and after searching the internet I can't find the antenna symbol to turn it off!!
Any ideas,
Many thanks,
Brian Leach |
Maxi Regular Visitor
Posted: Mon Aug 01, 2005 4:25 pm Post subject: Re: Flight Mode |
brianleach wrote: |
On the XDAIIs its on the top task bar between the O2 logo and the speaker symbol, just tap it and you get the option to turn off Flight Mode. Presumably if you've got Flight Mode on you've not been able to use your phone or GPRS to get the traffic data......Apart from the traffic data and being able to phone POIs it shouldn't make too much difference to the running of Tomtom (it'll still be full of bugs and the routing and maps will be crap!! - joke ) |
Posted: Mon Aug 01, 2005 5:14 pm Post subject: Flight Mode |
Thank you for all the help.
Rather embarrassingly the Flight Mode seems to have disappeared as mysteriously as it appeared.
I can still access all the services and at least I shall know the score if it re-appears.
Brian Leach |
