tom9851 Frequent Visitor
Joined: Feb 14, 2004 Posts: 283 Location: Warrington, Cheshire.
Posted: Wed Jul 20, 2005 9:51 pm Post subject: Annoying bluetooth browser! |
I have recently started using a Globalsat BT-338 with my TTN3 and am really pleased with it. However I find the constant popping up of the bluetooth brower to be a real pain. I can't even just load TTN to browse the map etc without it popping up all the time - any way to stop this?
Tom _________________ ___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338 |
linknet Frequent Visitor
Posted: Wed Jul 20, 2005 10:20 pm Post subject: |
Here's something you should try (credits to pocketnavigation.de). You need a registry editor for this.
HKLM\SOFTWARE\Widcomm\BtConfig\Autoconnect\000x
(000x is 0008 for com8 )
add an entry (DWORD)
BtBrowserEnabled=0
This should stop the BT browser from popping up, and the last connected device will be reconnected.
If you search previous posts for "BtBrowserEnabled" you will find more information.
Roger |
Posted: Thu Jul 21, 2005 6:14 am Post subject: |
Roger,
Thanks for that - I will have a look at previous posts for more info as I gather it was a common problem.
Posted: Thu Jul 21, 2005 8:53 pm Post subject: |
BTW, does this problem exist with 5.00/5.10?
Posted: Thu Jul 21, 2005 9:25 pm Post subject: |
Quote: | Does this problem exist with 5.00/5.10? |
On my PDA with TTN 5.00 I needed the BtBrowserEnabled=0 key and had to enter it manually.
With 5.10 the software actually installs this key. If you delete it, the next time you run TTN 5.10 it gets recreated.
Roger |
Posted: Fri Jul 22, 2005 5:36 am Post subject: |
OK thanks.
