Pocket GPS World :: View topic - Combining POIs
Combining POIs
PJEvans
PostPosted: Sat Jun 11, 2005 8:17 pm    Post subject: Combining POIs Reply with quote
I've recently bought a France map for my TTG300 and am currently downloading some POIs ready for a holiday next week. I've just downloaded a couple of the French supermarket chains from POIHandler and would like to combine them into one big category. So a couple of questions if anyone can help please.
1. How do I combine what I've downloaded into one POI category?
2. Does anyone know any other sites where I can download POIs for France?
Thanks in advance all. 8)
JimmyTheHand
PostPosted: Sat Jun 11, 2005 8:39 pm    Post subject: Re: Combining POIs Reply with quote
Use the OV2 tools on tomtom site to convert to the text files, then using notepad combine them into one file - then use the tools to convert back to ov2 files
J.
PJEvans
PostPosted: Sat Jun 11, 2005 9:56 pm    Post subject: Reply with quote
J.
Thanks for the info, I understand the principle but how is it done? Confused
I've downloaded the program, but when I open the dumpov2 file I cant see what I need to do.
Can anyone explain in plain English what to do please? Sorry if it's easy or obvious but I'm sat here totally bemused. Embarassed
Thanks Again
JimmyTheHand
PostPosted: Sat Jun 11, 2005 10:28 pm    Post subject: Reply with quote
PJEvans wrote:
J.
Thanks Again
copy the "dumpov2.exe" and "makeov2.exe" into a new directory, then copy the ov2 files into the same directory. Double click on the dumpov2.exe - for each ov2 file should appear an .asc file - you can open these files in notepad (you can either use open with, or just the open from file menu).
Create you desired file - save this to a the directory. Now run a command prompt (run dialog and type "cmd" in 2K/XP - "Command" in 98) change to the directory you have the files in. Then type makeov "filename.asc" - a new ov2 file should appear
J.
JimmyTheHand
PostPosted: Sat Jun 11, 2005 10:29 pm    Post subject: Reply with quote
[quote="JimmyTheHand"Command" in 98) [/quote]
should be 98 )
J.
Oldboy
PostPosted: Sat Jun 11, 2005 10:51 pm    Post subject: Reply with quote
In Explorer if you drag an .OV2 file to Dumpov2.exe it will do the same.
You just need to Open with ... Notepad for both files and then Select All of one file and Copy/Paste onto the end of the other file.
In Explorer again just drag the .ASC file to Makeov2.exe and it will create the .OV2 of the same name, also the default BMP unless one already exists.
PJEvans
PostPosted: Sat Jun 11, 2005 11:03 pm    Post subject: Reply with quote
J.
I've done the above, and opened them with note pad 8) Now have 6 .asc files
Sorry but I don't understand what to with this bit Embarassed Do I need to copy them into a new folder then what?
Thanks for your assistance by the way :D
PJEvans
PostPosted: Sat Jun 11, 2005 11:22 pm    Post subject: Reply with quote
Glad to someone else is still up Laughing
I now have 6 .asc files, how do I combine them prior to dragging them to the Makeov2.exe ( just dragged them all over individually and ended up with 6 .ov2 files which didn't help as I was them back where I started) Embarassed
PJEvans
PostPosted: Sun Jun 12, 2005 12:02 am    Post subject: Reply with quote
Thanks for all your help guys...All sorted Laughing
Funny how when you get into these things and with a little help and guidance these things arn't as difficult as they first appear. Confused
All I have to do now is load it onto the TTG
Thanks again
DocL
PostPosted: Sun Jun 12, 2005 7:52 am    Post subject: Reply with quote
PJEvans, {not a car dealership are you?? Smile }
With regard to French Hypermarkets, Banks, Decathalon, 'Radars', Cheap petrol places, and Motorhome Aires (Aires Camping-Cars) and numerous other POI's then go here;
http://www.gpspassion.com/forumsen/default.asp?CAT_ID=15
You need to register, but I have a myriad of these POI's on my French Map. Bloomin' useful.
Cheers, Doc L.
JimmyTheHand
PostPosted: Sun Jun 12, 2005 9:02 am    Post subject: Reply with quote
Must remember to remember that one next time I am trying to explain how to build up a command line instruction - so used to just running command lines, dragging files onto it/using tab key (XP) to build it up I tend to forget tricks like that.
J.
JimmyTheHand
PostPosted: Sun Jun 12, 2005 9:03 am    Post subject: Reply with quote
Sush - don't tell the boss, he might realise that he is paying too much Smile
J.
PJEvans
PostPosted: Sun Jun 12, 2005 9:57 pm    Post subject: Reply with quote
No unfortunatley not, might have a bit more money if I was
Thats where I got the Supermarkets from, I was just wondering if there were any other sites that people used?
22.052 (08 May 24)
