Pocket GPS World :: View topic - 307, tomtom 3 help needed urgently
DM72
PostPosted: Mon Jul 12, 2004 9:11 pm    Post subject: 307, tomtom 3 help needed urgently Reply with quote
I've just taken delivery of my Globalsat 307 cf gpsr and when I set it all up on my 2210 I find that it's very slow/laggy.
I'm not sure which of the option I should have choosen for the installed gpsr as I can't see the 307 on the list.
So, which one should I use and is there anything I can do to speed it up a little.
Any help would be very much appreciated as I will be using it when I go on my hols tomorrow and really bought it to try out while I'm away.
PostPosted: Tue Jul 13, 2004 2:27 pm    Post subject: Reply with quote
try using a standard setting. COM4, MNEA 4800 or 19200
Steve999
PostPosted: Tue Jul 13, 2004 4:55 pm    Post subject: Reply with quote
Hi, I use a BC-307 in a 2210 with good results.
If you set it at 4800, you will find an option in the com port menu for a 'generic cf card. Select this one and then tick the box to lock it. This option will only appear when the 307 is inserted.
After you remove the 307, you will need to set the com port back to 'serial cable on com 1' (and tick to lock it) if you want to successfully use route demonstration on Tomtom.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
22.071 (03 Jul 24)
